1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
snow plow prep pkg
Old 12-21-2010, 10:12 AM
pkenn7's Avatar
pkenn7
pkenn7 is offline
snow plow prep pkg
i have an 02 (v10) with the snow plow prep pkg..... any body know how many amps the altenator is??
Old 12-21-2010, 10:59 AM
rjfetz1's Avatar
rjfetz1
rjfetz1 is offline
Just because you have the snow plow prep package does not mean you have a larger alt. Back then i'm thinking 110 or 120 amp.
Old 12-21-2010, 11:16 AM
bpounds's Avatar
bpounds
bpounds is online now
Here are the 2002 specs:
https://www.fleet.ford.com/truckbbas...2/fsersdcd.pdf
You will find throughout that your alternator is 130 amp. No mention of any different rating with snowplow prep. This surprised me as well.
Here are the 2006 specs (my truck as an example):
https://www.fleet.ford.com/truckbbas...essd-ms_06.pdf
You will find throughout that the alternator is 110 amp. And then on page 47 you will find the notation for a 140 amp with snowplow option.
Apparently your 2002 has a 130 amp, doesn't matter if you have the SP prep. At some later time, Ford starting downgrading the standard alt to 110, and offering a 140 upgrade, but only for the diesel.
This is IF we can believe the spec sheets.
Old 12-21-2010, 04:56 PM
pkenn7's Avatar
pkenn7
pkenn7 is offline
thanks for the input....thats weird because if i type in my vin on the ford parts website my only option was 110 AMPS.......my mechanic buddy said there has always been a problem with ford only putting in 95 amp alternators.......and no markings on mine at all....
pkenn7
12-06-2010 08:26 AM
HarleyScooter
07-07-2010 05:37 AM
350Man
Car/truck Buying Advice
12-23-2005 08:19 AM
SDTruckMan
12-14-2005 08:53 PM
myersdave
09-23-2004 06:05 PM
Quick Reply: snow plow prep pkg
