You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Hello,
I have a 2001 Ford Lightning with 80K miles on it. All stock motor with exception of exhaust. On the way to work today I accelerated on a freeway on ramp to get infront of a semi and when the supercharger went into boost from vacuum I experienced a great loss of power and a shudder. Motor runs fine as long the supercharger is in vacuum, but once you start to lay into the throttle and the supercharger kicks in I lose power and it almost feels as if I have hit rev limiter as far as the shudder and loss of power, but thre RPMs are nowhere near redline. Any ideas?
it maybe bad injectors and your not getting enough fuel, or even a clogged fuel filter... check the small stuff before the big...it could even be an air filter...also see if any codes are being thrown
__________________
-04 F250 XL Diesel... Build In PROGRESS!!!
getting some things done to it !!*RiffRaff I/C BootsAlong with alot of other things from Clay
-08 4x4 ranger.. *3" Superlift, *Superchips, *33's, *intake mod, *magnaflow muffler, *full kenwood system
Yeah, my friend has a code reader that I am going to check out tonight. I have been doing some research and it sounds like it may be something wrong with the Supercharger Boost Solenoid. It runs like a charm under normal load in vacuum, I know these have secondary fuel pumps, I guess there could be an issue there with fuel delivery. Thanks for the reply and ideas!
Im having the same problem. Just had the heads replaced and the mechanic can not find any vacuum leaks. There was a code that came up, when the check engine light came on, for excessive fuel and he fixed that but no change in the way it performs. Also, it sounds like there is air blowing through the vents but there isn't. As of right now, there is no engine codes coming up. Did you find out what was causing your problems?
