fuel pressure problem, need help !!
I have a 1999 F-350 7.3 diesel with a 6 speed manual transmission. The truck has 116,000 miles. Recently, I drove the truck and it ran fine for about 60 miles and then acted as though it was starving for fuel. If I kicked the turbo in, it would just start to slow down until I would pull-over to the side of the road and let it idle for a minute and then it would run OK as long as I did not kick in the turbo. I changed the fuel filter and it seemed to correct the problem, however after driving the truck for about 20 miles, it did the same thing. I have replaced the fuel pump twice and compared the fuel flow into the fuel bowl with that of a 2001 F250 7.3 that a friend has and mine is quite a bit less. I pulled the bed off and checked the gas tank canister and all looked OK. I put it all back together and the truck ran great for about 20 miles, I had the cruise control on and it just started slowing down and acting like it was not getting enough gas. I pulled over and let it idle and was able to drive home as long as I did not give it too much pedal. The next day it ran fine, however I did not drive it 20 miles nor did I get into the turbo. There seems to be a problem getting fuel to the fuel bowl, but only after it is driven several miles and the problem temporarily goes away after the truck sits. I was going to take it to the dealer as I have run out of ideas, but after reading some of the comments, I thought I would try this forum. Any suggestions would be greatly appreciated. I have bee fighting this problem for about 4 months.
Thanks for the quick response. I have not done any tank modifications. Is the fuel pressure regulator after the fuel filter housing? We checked the fuel flow into the fuel filter housing. When we pulled the canister out of the tank (to check for fuel or air leaks) we did not notice anything in the fuel and we cleaned the screen on the bottom of the fuel intake line. We did not take the canister apart, but wondered what was inside. I will take the bed back off and pull the canister apart and check the screens. Will I run into any problems taking the canister apart? We have always thought the problem was somewhere between the fuel pump and fuel. This problem has occured when the tank was full or at any level.
Do we just clean the screens or replace them?<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
What are the tank mods?<o></o>
<o></o>
Where, specifically, between the tank and the fuel pump is the filter to be installed and do you know what the <?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-comffice:smarttags" /><st1:City w:st="on"><st1lace w:st="on">Napa</st1lace></st1:City> part number is?<o></o>
<o> </o>
Thanks again for all the help. I just want to be sure I fully understand and I do the work correctly. <o></o>
<o></o>
<o></o>
<o> </o>
The FPR on a stock fuel system is one of the most under-rated and most overlooked items in the fuel system.
If the heart of the fuel system is the pump, then the FPR is its soul.
Any damage or cracking of this seat will not show up during startup, flow test or idle. It will majorly effect your fuel pressure once you get moving.
I expierienced the same symptoms you are describing less than a week ago. I cleaned the screens and tank out just as f350-6's great picture shows and that solved my problem. FYI the fuel pressure on the lift pump should be between 30-80 psi, seems like a pretty broad range to me! but that is what I was told.
You need to clean the junk from the screens.
