I-beam pivot bushings
I'm in the process of my disc brake swap on my '66 F-100. I am using a '75 F-100 as a donor. I removed the I-beams from the '75 today and the pivot bushings are shot. I was able to knock out one of the bushings pretty easily, the other one took a little more effort. My question is in regard to the bushings. What came out was the inner metal sleeve surrounded by a piece of rubber. There appears to be an outer metal sleeve which is still in the I-beam. I need to know if that outer metal sleeve which is still in the I-beam needs to be removed or if that is part of the I-beam. I am thinking it was part of the bushing and should be removed but wanted to double check before I tear it up trying to get it out. Also, is there a particular good method to get the outer sleeve out? If I had the new bushings, the answer would be obvious I'm sure but I don't. Any info appreciated.
Mark
Mark
Mark
Mark
Axle pivot bushing set #4.3119 for 65-79 Ford F100/F150. You have to leave the old outer metal sleeve in place, though. Clean it well and slide the new urethane bushing in with a new inner metal sleeve.
Lost_in_tx
10-02-2016 02:56 PM
Treacy
07-05-2016 02:40 PM
annaleigh
05-23-2016 02:11 PM
eyewall
10-24-2015 07:01 PM
Matt67
08-22-2001 02:50 PM
