white smoke from exhaust
Old 04-09-2010, 07:48 AM
newblder's Avatar
newblder
newblder is offline
I finally took the truck for a drive last night after it has sat all winter and I had just finished rebuilding the front suspension and steering. When I first started the truck there was white smoke and water(?) comming out of the exhaust. It has sat for a while so I figured it was just condinsation that was in the exhaust. After it warmed up I took it for a drive (I really like the new steering) and it was still doing it (white smoke) but not as bad and there was still water dripping out but again, not as much.
I checked the dipstick and it had condensation on the upper side of it and the oil didn't look milky. I checked the coolant (after it had cooled down some) and it looked clean. The exhaust doesn't give off a sweet smell that I can tell but I wasn't on my hands and knees sucking on my tailpipe either.
My plan was to check the spark plugs to see if any of them are white. What are some other things I should look for?
Old 04-09-2010, 09:28 AM
GreatNorthWoods's Avatar
GreatNorthWoods
GreatNorthWoods is offline
I hate to be the bearer of bad news but the last time I had a problem like that it was a cracked head. After the engine warmed up it would not smoke but everytime it sat until it was cold and restarted I got a lot of white smoke out one side of the exhaust. Mine didn't give off a sweet smell either. The crack was so slight that when the engine warmed up the leak was practically negligible. It would also miss on one cylinder at idle but fired on all cylinders after it warmed up. It could also be a bad head gasket or a cracked block. I noticed you live in North Dakota. I assume you had plenty of antifreeze in it for the winter...
Old 04-09-2010, 09:38 AM
newblder's Avatar
newblder
newblder is offline
I kept in in the garage this winter so it wasn't AS cold cold but it was still cold in the garage. I made sure the antifreeze mixture was good before winter. It's only got about 500 miles on the motor. I bought it as a rebuilt longblock and it sat for almost 2 years before I installed it in the truck and ran it. I know seals can dry up with it sitting that long. Would this plus winter have anything to do with it?
Old 04-09-2010, 09:40 AM
newblder's Avatar
newblder
newblder is offline
I forgot to add. The engine runs great. Doesn't misfire. Just runs nice and smooth. Starts up nice and easy.
Old 04-09-2010, 10:36 AM
Old F1's Avatar
Old F1
Old F1 is online now
It is just condensation, as the weather is still cool, it will cure itself …….this spring ..........when it warms up outside.
(OK, I have told you what you want to hear,…...............keep in mind that I’m very often wrong)
Old 04-09-2010, 11:31 AM
GreatNorthWoods
Sitting should not have hurt it nor the cold if you had sufficient antifreeze. Unless there was a screw-up on assembly it's probably just condensation as Old F1 suggested. Keep an eye on the coolant level and drive it some more. If it is something like a cracked head or bad head gasket the white smoke will be worst on a cold start-up and usually out of one side only...
Old 04-09-2010, 12:13 PM
Julies Cool F1's Avatar
Julies Cool F1
Julies Cool F1 is offline
White smoke, or steam?
Does it tend to disappear shortly after it leaves the exhaust? If so then it's steam.
Black smoke is unburned fuel, and gray smoke is burned oil.
Steam can be caused by condensation but should be gone within 3-5 minutes of your engine start up. All that latent water should be evaporated by then - that is is it is just condensation.
BUT, if it continues, then you have a water source that is supplying water to your cylinders. And that means a cracked block, cracked head or most likely, a leaking head gasket. It could be VERY small.
Be sure to check your coolant for traces of oil, and be especially noteworth of any water in the oil - it will appear on the dipstick or at oil changes as a milky white substance.
Good luck!
Old 04-09-2010, 12:45 PM
newblder's Avatar
newblder
newblder is offline
I think you could say it's more like steam. It disipates not long after it comes out the exhaust. I looked at the oil and coolant but didn't see any signs of a problem (oil in coolant, milky oil, ect) but I'll keep an eye on it.
I drove the truck around for about 10 min yesterday and it still had steam comming out but couldn't see any signs of something being wrong other than that. I'll keep a close eye on it. Thanks for the advice.
I did like Old F1's advice best. It doesn't cost me anything.....now.
Old 04-09-2010, 12:53 PM
Julies Cool F1
Old's advice is solid. But honestly if you drove it for 10 minutes and it was still doing it.......I'm skeptical about it being just condensation.
If it's a crack or a head gasket, it will get worse - you'll know.
Do your self a favor. Drive the truck around for about 100 miles and change the oil to check for water in it.
Old 04-09-2010, 03:44 PM
newblder's Avatar
newblder
newblder is offline
The joke was not to attack Old F1. I appreciate everyone's advice. It was just a joke.
I won't get a chance to drive/work on the truck this weekend but I'll run it next week and see how it goes. I'll report back after I find something out. Thanks again.
Old 04-10-2010, 12:59 AM
Julies Cool F1
I took what you said as a joke, but I didn't want to contradict him either, thus my statement.
Old 04-10-2010, 09:48 AM
daves54's Avatar
daves54
daves54 is offline
Has the coolant level dropped at all?
Old 04-10-2010, 09:00 PM
newblder's Avatar
newblder
newblder is offline
The coolant level hasn't dropped. Not enough that I could tell a least. I'll be able to give a better explanation in things after I drive it some this week.
Old 04-10-2010, 10:06 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
If you let it sit for a couple days, and drain a couple cups of oil out of it (yes, you can do that, it's a mess, but...) into a clean container, look for water. It can take a while to settle out, but it will always eventually settle to the bottom of the pan. That's if a cylinder wall is cracked. If it's a head gasket, it may not ever leak into the oil, the coolant may just leak into the cylinders and get burned. It would usually get worse when the engine is hot if its either (pressure in the cooling system).
Old 04-11-2010, 03:58 PM
newblder's Avatar
newblder
newblder is offline
I just checked the spark plugs and a couple of them were loose. The spark plugs were all a little dark but one was a little lighter that the others. Not much but some. I checked the coolant level and i was down just a little. There was also some condinsation on he dip stick and a very small amount of milky white substance on the dipstick and in the oil. The truck has sat since thursday night. Any ideas? I'm going to change the oil tomorrow night so I haven't drained i yet to see what it looks like.
Quick Reply: white smoke from exhaust
