Replacing read pinion seal
Mark the rear driveshaft (paint or what ever) so you put it back in exactly the same place. Remove the rear driveshaft, remove the pinion nut, remove the driveshaft yolk, inspect yolk for a groove where the seal rides in it, replace yolk if needed, remove pinion seal, put some vasoline or other light (white) grease on the inside of the new seal, install new seal, install yolk, torque pinion nut to correct specs ( should use new pinion nut) reinstall rear driveshaft. you're done.
stephen.south
02-28-2012 12:53 AM
