door ajar light
door ajar light
Here's hoping someone can help.
Door Ajar light on always
no door chime
all 4 doors, window and tailgate switches heavily sprayed with contact cleaner.
doors do not auto lock at 5mph
dome lights go out at 5mph
radio goes off with the key now
all fuses good
i just wish i knew where to start without pulling all 6 switches to check each one.
thanks in advance for any help
<!-- / message --> <!-- controls -->
no door chime
all fuses good
I'm guessing this is on the 2002 Explorer in your profile. If you want to get a feel for which door switch is the culprit, a professional scan tool would be the easiest way. They have the capability to access the GEM module and look at each of the door switch inputs and report "Open" or "Closed."
If you don't have access to this type of scan tool at a reasonable cost, then you could find a wiring diagram for the GEM and, using a multimeter, back probe each of the switch inputs to see which one is hanging up. I have the factory wiring diagram for the 2002 model year at home if you need me to dig up the wiring diagram.
-Rod
-Rod
