Use the pan, it shield the manifold from heat. I wouldn't use any gaskets on the ports unless you have leak problems. Lots of guys use RTV sealant for the end pieces.
I second that, just did mine last weekend, get the felpro gasket (metal) and use some RTV instead of the end rubbers, I used the napa gray and it sealed great.
Use the valley pan gasket.It will help cut the heat in the manifold by keeping the hot splash oil from the lifter valley away from the bottom of the manifold.
