Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
  #1 (permalink)
Old 03-27-2010, 12:47 PM
ntty1 ntty1 is offline
Garage is empty, add now
ntty1 is starting off with a positive reputation.
firing order on f150 4.6 1999
can u tell where the # 3 plugs at on what side of truck
  #2 (permalink)
Old 03-27-2010, 01:31 PM
stephen.osborne1's Avatar
stephen.osborne1 stephen.osborne1 is offline
2010 Ford F-150
My Garage
stephen.osborne1 is gaining momentum as a positive member of FTE.
this is the 2009 and newer forum. This should really be in the 97-03 forum. But to answer your question, #3 is on the passenger side, third one back. For future reference, when you open the hood and are looking at the motor (on a V-8) the cylinder closest to you on your left is #1. Behind that is #2, 3 and 4. On the right is #5, 6, 7 and 8. Pretty simple. The same strategy holds true for v-6 and v-10s as well. Inline motors are pretty self explanatory. #1 in front and go back from there.
I assume you are asking this question because you fouled a plug or coil on plug. If so, remember to put anti-sieze on the new plug threads. If the plug doesn't want to thread, don't force it. You have aluminum heads and they can cross thread easily. If the motor shot the plug out and destroyed the coil on plug, you need to take the truck in and have a professional install a helicoil.
__________________
2000 f-150 XLT SCAB 4X4 5.4, Auburn Limited Slip 3.55
1966 Mustang GT w/ 306ci/325HP, T-5, dark blue pearl metallic
1977 F-100 Custom 2wd Stepside 300 I6, AOD
2009 Kawasaki KLR 650
2010 F-150 FX4 SCREW 6.5', Ingot Silver, ARE Z series shell, 2" AS Leveling Kit
  #3 (permalink)
Old 03-27-2010, 04:26 PM
code po303
thank for info im going to change spark plug i'm getting code po303 i changed spark coil truck still acting up
  #4 (permalink)
Old 03-27-2010, 05:17 PM
loose #3 plug
found loose spark plug # 3 install new plug truck runs great
  #5 (permalink)
Old 03-27-2010, 07:52 PM
Ultramagdan's Avatar
Ultramagdan Ultramagdan is offline
1998 Ford F-250
Ultramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud ofUltramagdan has much to be proud of
That's the kind of fix we all like to find.
__________________
Dan
1998 F250 LD 4X4
2004 Explorer EB 4X4
2006 KLR 685
  #6 (permalink)
Old 03-27-2010, 09:13 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud ofLxMan1 has much to be proud of
4 8
3 7
2 6
1 5
front
__________________
Jimmy- FTE Moderator
88 5.0 LX Mustang
63 F100 351W/C6
Tags
150, 1997, 1999, 2003, 46, 99, cylinder, engine, f150, firing, ford, motor, order, truck, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
