I have a 2004 v10,i went for my inspection and they told me i failed the idle test.I went to an indepent nj inspection station after that and he told me it was most likely the banks chip i installed in the truck about 4 years ago.I have the complete banks system from a to z,which is rated 50 state legel.Can any one help with this problem, can i send the chip back and have it checked?
I would clean the MAF, then take the Banks chip off and see if it will pass. I'm not sure how you would do that. If you have your install instructions it should say. If I remember right the Banks is an add-on type chip. If it does pass, then contact Banks to see what they say.
