226 Problems
Old 03-26-2010, 09:54 AM
bailegb's Avatar
bailegb
bailegb is offline
226 Problems
The saga continues. I recently bought a 49 F3 without an engine, but it did have the 4 speed transmission installed. As luck would have it I found a 226 flathead 6 only 200 miles away. The engine is in great shape but the problem is it came out of a car and not a truck. I found a set of front motor mounts that bolt right on and figured I was in tall cotton. Now my issue is the 4 speed does not bolt up to the engine. Obviously the car engine has a different starter plate that is not compatible with the 4 speed. Any ideas where I can find a starter plate for a flathead 6 that bolts up to the 4 speed? Any ideas will be appreciated.
Old 03-26-2010, 11:32 PM
fixnair's Avatar
fixnair
fixnair is offline
Greg, you might have better luck posting in the older, classics and antiques section under the 48-60 F1 & F100 & larger forum. Things are a lot more active up there.
Old 03-27-2010, 09:26 AM
bailegb's Avatar
bailegb
bailegb is offline
Thanks I will do that.
critchdizzle
Ford Truck Parts for Sale
01-11-2017 10:47 PM
knuckleharley
Flathead V8 & Flathead 6
01-05-2017 05:26 PM
rswhitmore
05-20-2016 07:34 AM
sam03
01-19-2015 08:10 AM
restoringmy46
01-09-2006 10:15 PM
Quick Reply: 226 Problems
