226 Problems
Old Mar 26, 2010 | 09:54 AM
bailegb's Avatar
bailegb
226 Problems
The saga continues. I recently bought a 49 F3 without an engine, but it did have the 4 speed transmission installed. As luck would have it I found a 226 flathead 6 only 200 miles away. The engine is in great shape but the problem is it came out of a car and not a truck. I found a set of front motor mounts that bolt right on and figured I was in tall cotton. Now my issue is the 4 speed does not bolt up to the engine. Obviously the car engine has a different starter plate that is not compatible with the 4 speed. Any ideas where I can find a starter plate for a flathead 6 that bolts up to the 4 speed? Any ideas will be appreciated.
Old Mar 26, 2010 | 11:32 PM
fixnair's Avatar
fixnair
Greg, you might have better luck posting in the older, classics and antiques section under the 48-60 F1 & F100 & larger forum. Things are a lot more active up there.
Old Mar 27, 2010 | 09:26 AM
bailegb's Avatar
bailegb
Thanks I will do that.
critchdizzle
Ford Truck Parts for Sale
Jan 11, 2017 10:47 PM
knuckleharley
Flathead V8 & Flathead 6
Jan 5, 2017 05:26 PM
rswhitmore
May 20, 2016 07:34 AM
sam03
Jan 19, 2015 08:10 AM
restoringmy46
Jan 9, 2006 10:15 PM
