Timing Chain Cover Gasket replacement
I have a 96 Explorer 4.0L V6 that is leaking coolant around the timing chain front cover. Do I need to remove the oil pan to replace the timing chain cover gasket?
Another question....can the oil pan be removed without taking the motor out of the vehicle. It looks like remove the starter, a bunch of bolts and the oil pan should drop straight down.
Thanks.
Thanks.
Please share a follow-up on the coolant leak where you felt you needed to change your timing chain cover’s gasket. I had s similar experience and thoughts until I did some serious tracing and took pics where I c/n see. My 1993 Explorer’s leak appears to be coming from the thermostat housing above the cover (but runs along the seam of the cover and block.
My question: Is it common for the thermostat’s housing’s “O” Ring to go bad in 5-10 years due to the hot block where it’s located. This is my 2nd to go bad if this is the case as it was about 10 years ago. The 93 has more age than the 115,000 miles on it.
My post is at: https://www.ford-trucks.com/forums/9...ater-pump.html
1st page if the address does not work: Does coolant pass through 93 Explorer’s timing chain cover to the water pump?
wickware
JOW
wickware
JOW
LeoJr
02-13-2018 10:32 PM
waylen89
02-23-2016 06:34 PM
JustinP
07-23-2015 01:29 AM
