Door alarm at 75MPH????
I have a '99 F350 4x4 with 7.3L and auto. Whenever I'm on the highway and hit 75, the door dinger goes off (same chime as key in the ignition and door open). The chime goes off when I go back below 73.
Ideas?
Thoughts I had were: some kind of 4x4 overspeed sensor (didn't see one on the front diff..), aftermarket device installed for work crew, and malfunctioning multi-function switch.
Has anyone else had this problem?
Ideas?
Ok, now we're getting somewhere. Your '99 at work has done it since it was new. Is it a 4 Wheel drive model? AUTO? Diesel?
It seems electronic to me... if it was air flow or door locks it should have some intermittant changes in behavior, but it ONLY comes on when the truck is at exactly 75 on the speedo and subsequently does not go off until exactly 73 every single time. I wonder if that is something that Ford can turn on and off.
Called the Ford guys, the service guy says "no overspeed switch on the 4x4" and he suggested possibly the door switch (I have a date with some WD-40) and possibly the ignition module is grounding out somewhere. He also said to check the "pins" which sounded vague enough to be completely incomprehensible to the layman.
My brother in laws F350 had a rear door triggering the door ajar signal and light. He tried the WD 40 deal with no result. Would not quite beeping on our deer hunt this year, so when we got back he tore into the door and found a hole rubbed through the insulation of one of the wires. Taped it up and it is fixed after progressivly getting worse over 2 years
Supposedly, our trucks have a speed limiter. I've never gone fast enough to tell (my speedo's five slow @ 65) what happens, but if I'm right, our trucks have limiters at 80mph. I wonder if it's just telling you to slow down? I've also heard from a friend they're gonna raise the speed limit to 75 on the interstates over here sometime this year! Does that mean everbody's gonna have dinging Super-Duties? Supposedly, I can remove the speed limiter with my Superchips, but my truck's at the stock setting right now. So, I'm curious to see where this goes.
