9.75 clutch Pack
9.75 clutch Pack
I am putting in 4.56 gears and rebuilding the ls unit. I saw somewhere the order to put them in was the belleville washer then steel, friction, steel, friction, so on.
The order they are is steel, friction and so on until the washer is on the outside.
All this is with the pinion gears flat on the table. Which way is right?
So far there have been no shims behind anything, maybe the pinion bearing.
I will be trying to finish this up tomorrow. I read the tech bulletin and have searched for this order.
Thanks for any help,
Bryan
Bryan
pdqford
16
07-24-2019 06:07 PM
77f250429
41
03-11-2011 10:40 PM
bktoney
10-16-2001 05:41 AM
Bryan
08-04-1999 12:29 PM
03, 2004, 975, buy, clutch, clutches, differential, expedition, f150, ford, order, pack, shim, swap, transfercase
