Are the differences between a E-van and F- pickup 6.9L only external? Both are similar years, one a E-350 bus conv and the other an F-250HD 4x4 pickup.
I have no experance with vans, but every thing I have read is internaly every thing is the same. Externaly the fuel filter mount, oil cooler, and one exhaust manifold [drivers side I think] are different.
Farmert are you thinking of a van or a school bus, I know these things are different on a bus with an allison but think a van is basically the same. I could be wrong though.
If the drivers side exhaust is different andit would fit in a pickup it would have to be an improvement.
I'm with Farmert. Things I read that are different are as mentioned. Specifically with the oil cooler the header is different and the tube is a little shorter IIRC.
