throttle body coolant tube broke
I considered the pipe thread and hose fittings to make a repair; however I weighed it against breaking the tap off in the Throttle body or cracking it and decided not to try. I removed the hose fitting on the intake standpipe fitting and plugged that. Then removed the T-fitting in the heater hose and replaced with longer hose. I used a piece of the T-fitting-bracket to cradle the hose to the alternator bracket as original.
i think i am "seasoned" enough to say what i said.
think about it:
in cold climate this may help vaporize fuel but if the engine is hot and the air around it is also hot then the warm coolant would not be needed.
after the engine is warmed up the additional heat from the coolant will not help it and in fact may hurt it.
i am in ohio now but while living in l.a. i bypassed my corvettes coolant lines to the t.b. and it ran better then it did with it hooked up.
hope this clears my view of this up for you.
think about it:
On the B body Chevy board this topic was discussed as related to the TB on LT1s. Most noted small increases in performance with no issues in cold climates or emissions. Some users use a bypass system to retain the heat benefit in winter. Since the Caprice is the wifes car I decided to leave it stock, but I have a bypass on the 300 for summer hauling.
regards
rikard
regards
rikard
fl1a
10-07-2015 01:48 PM
lovemyexpy
1997-2006 Expedition & Navigator
19
10-29-2010 04:12 PM
Blujay96
04-13-2010 06:14 AM
