Headlights & Plow lights
This ones for you guys with plow lights. i want to hook up the truck/plow lights switch. i was wondering, with all the lighting and wiring problems on these trucks, how is the best way to go about hooking up the plow lights. Should i steal power from the switch or is it better to do the head light mod first? Im not looking forward to smoking myself out in the cab.
you can just run the plowlights off the headlights by using the headlight power wire as the trigger wire for the relay and then run a wire from the battery to the relay so then you wont be stressing your switch as bad.i would run a relay for high beams ,low beams and plow lights, i even ran a relay for my parking lights.so my switch hardly has any pressure
To tell you the truth, I never use my plow lights much. My truck has a 4 inch lift with 35" tires, so I had to mount the plow frame down low to make the plow a-frame level. So the plow is pretty much out of the way of the truck"s regular headlights, so I just use them.
Most states have height limitations for headlight height.
They have a list of state height requirements on a lift kit site, Rough Country if I remember right, and 54" was the highest I remember.
And in most states, plow lights are above that limit, so the answer would be yes.
For the wiring, I would wire mine using relays.
If you put a DPDT toggle after the dimmer switch and before the relays, when you flip the switch the main truck lights would move to the plow lights and the dimmer switch would dim the plow light.
Switch terminals
A B
C D
E F
Switch terminals A and B to plow lights low and high.
Switch terminals C and D to dimmer switch wires for low and high.
Switch terminals E and F to headlight low and high.
Most plow trucks have the blinker and park lights in the plow wired straight to the truck blinker and park lights so they all work together.
Switch terminals
A B
C D
E F
ok well i originally hooke up the lights to a separate switch so i could use the plow lights for work lights. but ive discovered that i dont use them that way that much. just when people are on the side of the road at night and i want my tail lights on anyways. i wanted to change it to free up a switch and make it look alittle cleaner. Maybe mount the plow/ truck switch near the head light switch
There's no problem with having plow lights installed with the plow blade removed, just as long as you used your regular lights and not the plow ones on public roads. When the plow is on tho many states require you to run the plow lights and not the headlights, as factory headlights usually fall behind the blade so the blade will block them from shining on the road ahead. Some states also require that the plow lights include not just headlights, but also marker lights and blinkers, for pretty much the same reason - when blade is on factory lights are hidden by it, so your driving intentions cannot be clearly communicated to other drivers.
