Double Din Stereo Install's 99-04
Have to grab the trusty Dremel. I just did it last night (took 15 minutes). Forgot to take pix though. Its easier to take out the dash (start pulling from the left driver's side) first. Dremel or file down the protrusions on the top and bottom not the sides. Right now its snug enough that I don't feel the need to secure it more than with the anchor from the OEM radio, but I may consider doing it later.
BTW, in my case the OEM radio was a PITA to remove. Hangars did not work. Had to take the dash out with the radio still attached and press the clips manually.
Search "double din" for more posts in the Audio & Video Systems, Navigation, Satellite Radio and Mobile Electronics section of the main forum.
I used the bolt on sides to attach it to the dash (dash and radio come out together now) and the kit came with a snap on trim ring to finish it off.....as you say a very tight fit
proudfrog
10-15-2017 03:19 PM
Whitey Ford
18
03-12-2017 04:03 PM
5280
05-25-2014 10:21 AM
bookpile
01-08-2011 06:12 PM
