I drive 50% city 50% highway with trailer on highway.
Thanks,
Robert
PS: will add tuner & larger exhaust
do you do much towing?
unfortunaly to change gears out on the trucks you will be spedning a pretty penny, unless you can do it yourself and not go crazy before you shim it all correctly.
i wanted to get mine done when i had my lift and it was about 1700 bucks including the gears that i was going to buy myself.
i think he was inquiring it the stock gears i think it is 3.73 is good for mpg not as good or pulling but if it is not hilly then it might work the gurus will chime in soon.
Correct, looking at stock gears. Getting close to buying a 99 with 4:10 limited slip.
Have an automatic 6.0 with 3.73 now. Not sure how the 6speed with 4:10 would do. I'm assuming better city & worst at 70 + mph. I guess better thru mountains on highway pulling big load.
