need more radiator info
about a week ago I asked for help finding a radiator for a 1948 f1 with A 351W AND AUTO-trans. one recommendation(from mechmagcn) said a good fit would be a mid 70's dodge truck radiator.
I need to more info. Spent over an hour at napa today and they could not find an easy match. found one with the water inlet and outlet apparent the wrong sides for a 351w. Can the radiator outlets be relocated without excessive cost? which dodge engine do I look for?
Any suggestions appreciated
on
If you have a driver's side outlet water pump the Dodge radiator won't work unless you move the bottom outlet to the other side. It's an easy job for a radiator shop if you have one in your area. I have a 75 Dodge truck radiator in my 48 with a SBC and it works great for that or for a passenger side outlet Ford engine. I've been looking at trying a 55-57 T-Bird radiator for my 49 with 302. The outlets seems to be right but I haven't physically laid eyes on one yet to be sure it will fit. The dimensions seem right...
