5.4L Oil Pressure Sensor Location
Old 02-23-2010, 08:44 PM
04mudslinger's Avatar
04mudslinger
04mudslinger is offline
I have a 2000 F150 5.4L 4x4. I understand the oil pressure sending unit is near the oil filter, correct? If so, does the oil filter need to be removed to get a hand back there to remove the sensor? I tried feeling around and couldn't reach it. If I have to take the filter off, how much oil will I lose on a cold engine? I am still 2000 miles away from a oil change.
I have the problem with the guage going to nothing and back up to normal in a matter of seconds. I don't have any loud noises, so I know I am getting oil.
Thanks!
Old 02-24-2010, 07:41 PM
chaser1602's Avatar
chaser1602
chaser1602 is offline
You wont lose any more oil than you do when you change the oil.Or just wait 2000 miles
Old 02-24-2010, 08:02 PM
vze2sgxa's Avatar
vze2sgxa
vze2sgxa is offline
Thanks!
I just did this replacement, I think it was a code 1248 or something like that pointing to sensor. The sensor is just above and slightly behind the filter mounting boss, you access it from behind the front diff, drivers side. Crawl under there and put a drain pan under it, you will catch about 1/2 to 1 full cup of fluid when you remove it. I had to buy the special oil sending unit socket from AdvanceAuto to get install it, none of my deep sockets fit over the part that connects to the pigtail. I was able to use a deep socket to remove the existing one - the old unit is smaller in size and socket fitting, the newer one is a redesign version, a little more stout, got it at Ford dealer. You will need a long extension and one swivel connection to get up and over the front diff to get at it. I used a long pick to pull on it and a long screw driver to gently lift up on the locking tab while removing the pigtail from sensor. The new OEM unit comes with threads coated with thread lock on it, but I added two turns of pipe tape just in case. Whole job takes about 1/2 hour, just take your time and don't cross-thread the new sensor, install it by hand then torque it down to spec. Turn the engine on to test, you won't have anymore problems.
Old 02-25-2010, 07:41 AM
04mudslinger
Thank you vze. That is the info I was looking for.
Mahu24
09-05-2017 09:14 AM
expedition_man
1997-2006 Expedition & Navigator
12-22-2016 02:54 PM
Glenn54
10-25-2016 07:33 PM
quick35th
05-09-2013 09:04 AM
packerford
2004 - 2008 F150
02-10-2013 09:12 PM
Quick Reply: 5.4L Oil Pressure Sensor Location
