Want to add heated mirrors, can it be done?
Old 02-23-2010, 08:10 PM
balderman's Avatar
balderman
balderman is offline
I have a 99 F-250 with regular extending mirrors, is there any way to putt heated mirrors on and run the wiring for it? Is there a factory wiring kit that I can get? Has anyone done this?
Thanks in advance..
Brian
Old 02-23-2010, 08:28 PM
mike brez's Avatar
mike brez
mike brez is offline
I put heated turn signal mirrors on mine.
Old 02-23-2010, 08:32 PM
WideOpenFord's Avatar
WideOpenFord
WideOpenFord is offline
How did you do it?
Old 02-23-2010, 08:33 PM
indyF-350psd's Avatar
indyF-350psd
indyF-350psd is offline
you can't fix stupid!
sure can! just get the 05 and later mirrors with the turn signals and heat on them and they will bolt right up and then you just run the 4 wires for the ground the heat and the turn signals and running lights. there is a write up around here somewhere just do a search for 05 mirror conversion and you will find the link in the thread. you also might want to wire in a switch for the mirror heat so they are not on all the time....
The following users liked this post:
Old 02-23-2010, 08:40 PM
Ponyboychris's Avatar
Ponyboychris
Ponyboychris is offline
Hit it!
I did it with a pair of heated '02 mirrors off an Ex. I don't have the turn signals but I love the heat. I just wired the heat to the electric window switches in each door. Here's the write-up.
New Mirror installation
Old 02-23-2010, 08:53 PM
mike brez's Avatar
mike brez
I wired the heat to a switch that is a key on power. I did not like the idea of them always on when the truck is keyed on.
Old 02-23-2010, 09:15 PM
Ponyboychris
Hit it!
One of these days, I will wire them to a defrost switch but they work for now.
Old 02-23-2010, 11:02 PM
BillyBob69's Avatar
BillyBob69
BillyBob69 is offline
Well thanks to PonyBoyChris, he gave me a switch for the defroster from a 91 Exploder for my heated mirrors that I put on my 99. The switch has the timer built into it so I just wired it up and away I go.
Switch
Parking lights
Turn signal
The following 2 users liked this post by BillyBob69:
Old 02-23-2010, 11:30 PM
jdw1's Avatar
jdw1
jdw1 is offline
BillyBob69, that truck needs cab lights, bad! Lol
Old 02-23-2010, 11:33 PM
BobbyDiesel71's Avatar
BobbyDiesel71
BobbyDiesel71 is offline
I am considering this swap/upgrade.
My 02 mirrors have no heat and I def prefer the turn signals in the mirrors vs w/o
Is the main issue the fact the heat always stays ON?
Old 02-24-2010, 07:34 AM
mike brez's Avatar
mike brez
I dont think it is a issue, If you were to get them on your truck from the factory thats how it would come. Personally I just did not like them on all the time considering the amount of time I use them.
Old 02-24-2010, 08:31 AM
Ponyboychris
Hit it!
Switch
Parking lights
Turn signal
I was gonna ask you if you got that switch in yet. Glad you got it going. Obviously I haven't wired mine up yet. I think I'll put my Exploder switch on my F650 dash that I have - once I get that in... I really need to get some time for this stuff.
Old 02-24-2010, 08:34 AM
Ponyboychris
Hit it!
Like Mike said, the factory wiring has them on all the time. If you can find a defrost switch from a early to mid 90's Explorer, they have an internal timer that will power your mirrors on for 15 minutes. That's the way to go. All you have to do is run a wire from the doors, thru the wire loom in the door jam to underneath the dash to the switch.
Old 02-24-2010, 09:34 AM
BillyBob69's Avatar
BillyBob69
Well bring yer parts an c'mon on over! Now that I have a workshop at the new place...No ... wait... An INSULATED and HEATED workshop... Weather no longer stops me from playing. **I still get tickled about the workshop** hehe
Old 02-24-2010, 09:53 AM
Ponyboychris
Hit it!
That's a great offer. I'll have to invite myself over soon.
Quick Reply: Want to add heated mirrors, can it be done?
