75 F-150 vin number
Are you sure the GVWR is 6700 lbs? No 1975 F150 4WD had that high of a GVWR. Which label on the door did you get that info from?
The Warranty Plate that is riveted to the door face, or the white Safety Standards Certification Label that is glued on?
What are the first three digits of the VIN? What is the MODEL code found on the Warranty Plate?
plate says *700 I can't tell if it is a 5 or a 6 it has been smashed although the rest of the plate is perfect?
door plate:133 RP F113 L 4A 08J
06700? 1975 75
VIN#--- RP 75
F113 4 08J A
Compare the VIN on the Warranty Plate with the VIN on the registration to see if they match.
People swapped damaged left doors with used doors. 99% of the time, they did not install the original Warranty Plate on the replaced door.
MODEL code: F113 = F100 4WD / 5700 lbs. Gross Vehicle Weight Rating.
So do i need to replace the emblems with F-100? did ford make a F-100 4x4 in 75?
F11YRX20525
113 / RP / F113 / L 4 / A / 08J / 6700 (5700) / 1975 / 75
F11 = F100 4WD Pickup.
Y = 360 2V.
R = San Jose CA Assembly Plant.
X20525 = 1975.
133" Wheelbase.
RP: R = Medium Ginger Metallic / P = Light Gold.
F113 = F100 4WD / 5700 lbs. G.V.W.R.
L 4: L = Medium Ginger Vinyl & Medium Ginger Cloth XLT // 4 = Styleside Pickup, Bench Seat.
A = New Process 435 4 Speed Manual Transmission.
08J: 08 = Ford 9" Rear Axle / 3.50-1 / non Limited Slip / 3300 lb. Rear Axle Capacity // J = Power Steering.
6700 > > should be 5700 lbs. Gross Vehicle Weight Rating.
1975.
75 = Phoenix AZ Ford District Sales Office, where the original selling dealer ordered the truck from.
D4TZ16720A .. F100 Emblem / Fits: 1973/76 F100 / Obsolete-Reproduced.
FTE sponsor carolinaclassics.com (800-598-4211) located in Durham NC has reproduced this emblem.
But....if you want NOS (New Old Stock) genuine Ford originals:
KINSEL L/M in Beaumont TX has ONE = 800-816-2894.
KLIMESH MOTOR SALES in Calmar IA has TWO = 563-562-3241.
