New gauges installed (pics)
Old 03-03-2011, 05:57 AM
TheBestKindOfEX's Avatar
TheBestKindOfEX
TheBestKindOfEX is offline
egt probe wire
Originally Posted by Snowseeker
Thank you!
One little note about temp gauge leads. The "wire" between the gauge and the probe is actually a copper tube so be careful not to kink it. They work like a thermometer, the heat at the probe raises the pressure in the tube to the gauge making the needle go up and down.
I'm not sure about that one. It looks to be a thermocouple probe type of thingy on one end and 2 bullet electrical connectors on the other end. Of course I was careful not to kink it during installation anyway.
This one is not like the thermocouple on an HVAC system that has a copper tube that runs all the way. It's just a wire bundle from the gauge to where the probe lead plugs in.
  #62
Old 03-03-2011, 08:01 AM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
Ah yes! If there are electrical connections to the gauge then no it is not a tube. I guess I should have been more specific. If the probe, lead, and gauge are connected as one from the factory and can't be disconnected then it is most likely a tube between the gauge and probe.
Sorry about that.
  #63
Old 03-03-2011, 05:11 PM
TheBestKindOfEX
no problemo
Hey snowseeker......I just put that in there because I thought you were considering getting the Glowshift gauges and you might want to know how this probe was made. It's all good.......
Along the same line of installing gauges, I found a great firewall pass-through location for wires and such. Looking in the engine bay near the drivers side there is silver tape. You can easily punch through it and it goes directly inside the cab. Inside the cab there is insulation that is precut in that area to move it out of the way, then put it back in place......these pics are before I re-taped the hole.....
Close up view of the area
General view of the area
  #64
Old 03-04-2011, 07:10 AM
SkySkiJason's Avatar
SkySkiJason
SkySkiJason is offline
Received 1,897 Likes on 1,145 Posts
Good pics! Thats where clutch stuff goes in SD's...
  #65
Old 03-04-2011, 07:46 AM
TheBestKindOfEX
I wondered why that big hole was there.......this forum is like having a neighborhood filled with nothing but Ford owners! It's like walking next door to look at your neighbors truck.......
  #66
Old 03-06-2011, 03:26 PM
dvldog458's Avatar
dvldog458
dvldog458 is offline
Great setup.....I just finished installing the EGT and Fuel Pressure and saw you installed the Oil Pressure gauge. Where did you tap into for the Oil Pressure sensor?
Here's a quick pic.
  #67
Old 03-06-2011, 04:17 PM
TheBestKindOfEX
wheredja get it
Originally Posted by dvldog458
Here's a quick pic.
Nice Part....who sells them?
I have not finished the oil pressure gauge yet. The factory oil pressure sender is just behind the oil filter assembly. It's a real tight spot there and the filter housing is so close to the sender that a deep well socket won't fit. I need more time to disassemble some things to get to it.
Since a Tee won't be able to screw in there, I'm planning on using a pipe nipple long enough to raise the Tee so I can get both sensors in there. The new sender will be remote mounted like I did the fuel pressure sender.
I'll take pics and post when I get into it.
  #68
Old 03-09-2011, 02:01 PM
dvldog458's Avatar
dvldog458
  #69
Old 07-25-2011, 07:31 AM
LionInTheSun's Avatar
LionInTheSun
LionInTheSun is offline
Just got my gauges and researching the installation. Did you hook up the boost sensor into the MAP sensor or did you tap into the intake? If you went into the MAP sensor háček you had any issues with the needle bouncing at all? Great post and pics, thank for your help.
  #70
Old 07-25-2011, 07:53 AM
dvldog458's Avatar
dvldog458
Yes, when I first installed the gauge I tapped into the rubber hose MAP line. It was bouncing alittle too much for me, so I replaced the hose and drilled and tapped the intake elbow. Much more stable in my case.
  #71
Old 07-25-2011, 08:02 AM
LionInTheSun
Thanks, think I'll go that route as well.
  #72
Old 07-25-2011, 11:29 AM
SkySkiJason
This is an excellent option to drilling a hole or tapping that hose:
Riffraff Diesel: RDP AIH Tapped Fitting
  #73
Old 07-26-2011, 12:14 AM
simplyrob's Avatar
simplyrob
simplyrob is offline
Awesome gauges, I'm so jealous!
  #74
Old 09-20-2011, 11:39 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
bump to the top.
hoping you guys with these gauges can report back in with quality and/or any issues. especially since they've been installed for a while. I'm looking to run these gauges since they'd be 1/3 the cost of similar Autometer gauges
  #75
Old 09-21-2011, 11:39 PM
dvldog458's Avatar
dvldog458
Still on the money bro!
Quick Reply: New gauges installed (pics)
