Rear End Gearing
#31
To be honest, I just wanted a half ton. I will not be hauling anything that would exceed a half ton's specs. I like the curves of the older vehicles. I wanted something that was pretty much bolt together which is why I picked an older pickup. It is a pretty truck and she is in good condition for her age.
Thanks for the information.
Cheers Dino
Cheers Dino
#33
F3 drivetrain
I posted this question along with another on a different thread (F3 Restoration) but it might be more appropriate here. I am restoring a 1949 F3 pickup with flathead V8 engine. The rear end is the 4.86. I was told that top speed on this truck will be around 40 mph with that ratio. Is this true? Should I consider converting to a 4.11?...there is a kit available to do so, I understand.
CarlH
Bedford, MA
1949 F3
1997 F150
CarlH
Bedford, MA
1949 F3
1997 F150
#34
Carl - I commented on your other posting. Here's Julie's gearing calculator to help you figure out the difference in road speed. Stu
Gear Ratio Calculator
#36
Are you all sure about that. My serial number also contains a Y and its an f-2. On the title but also all the specs match the F-2. I read somewhere that the Y denoted 3/4 ton
#37
Gary Lewis
22
10-18-2016 06:48 PM
fred_79f250
1997-2006 Expedition & Navigator
06-20-2016 08:14 AM
F-Superduty89
02-14-2012 09:35 PM
46yblock
10-23-2005 12:11 PM
