ft361 difference fe 360???
The crank is steel and externaly balanced with a larger snout. The block has extra main webbing and sometimes thicker cylinder walls. The heads have smaller ports to promote very low RPM efficiency. The distributor hole is larger but can be bushed down to fit the FE dizzy.
ScallyWaggler
11-19-2021 10:48 PM
ScallyWaggler
06-05-2015 11:12 AM
ford1940deluxe
08-23-2010 09:50 AM
Scouder
06-21-2005 03:24 AM
