Closed
Doors
Bagley
Here are the pics of the doors...well, the bottom of the driver's door is in great shape as you see. The passenger side has some rust forming. I either overlooked it or plumb forgot. I'm sure you want the driver's, thoughts on the passenger's?
-----DRIVER'S SIDE DOOR-----
-----PASSENGER'S SIDE DOOR-----
Here you can see some minor rust. Looks like Andre the Giant tried to bite onto it! I also tried a wire wheel on the upper right to test out the wire wheel. Flash rust has resulted from being in storage in non-controlled climate. No big deal since both doors should be media blasted anyway.
Passenger side looks worse because it's dirtier than the driver's side. I promise, it's not rusted out.
-----END-----
-----END-----
