still having issues
Old 02-01-2010, 08:18 AM
-ZIXXER-'s Avatar
-ZIXXER-
-ZIXXER- is offline
Angry still having issues
Ok, I have been having some issues with my speedometer jumping pretty bad, my cruise won't stay set and pulses pretty bad, and my abs light comes on. I changed the vss in the differential, and now the problem seems to have gotten worse. Any other ideas? I appreciate the input ya'll.
Old 02-01-2010, 08:25 AM
Talyn's Avatar
Talyn
Talyn is offline
Hit it with a hammer.
Old 02-01-2010, 09:19 AM
jeep1947's Avatar
jeep1947
jeep1947 is offline
Also check the wiring from the sensor as well as the pins on the plug. Wiring can get chafed and cause these problems. Hope this helps.
Old 02-01-2010, 09:32 AM
Talyn's Avatar
Talyn
Talyn is offline
Hit them with a hammer also.
Old 02-01-2010, 11:06 AM
DRRXR's Avatar
DRRXR
DRRXR is offline
dunno BUT I WILL POST THIS LINK ANYHOW
Electrical: Instruments
SOUNDS REASONABLE.
Old 02-01-2010, 11:44 AM
Action4478's Avatar
Action4478
Action4478 is offline
Is the mounting surface for the VSS clean?(no rust) Have you looked very carefully at the wiring leading to the rear end?.. Was the replacement VSS from Ford?...
Old 02-05-2010, 09:08 AM
-ZIXXER-'s Avatar
-ZIXXER-
-ZIXXER- is offline
I got it from o'rielly. I think I will get a motorcraft one this time. They are considering it an abs sensor though. Is this the same as a vss on our trucks or???? Thanks for the help!!!
Old 02-05-2010, 09:34 AM
strokin'_tatsch's Avatar
strokin'_tatsch
strokin'_tatsch is offline
i thought the RABS could cause an issue with the cruise and speedo jumping??? would explain the ABS light perhaps. i'm not sure though b/c i have never had this problem.
William, go hit yourself with a hammer.
Old 02-05-2010, 12:21 PM
Talyn's Avatar
Talyn
Talyn is offline
It didn't work Travis.
