Offroad & 4x4
Pinion Angle
Old 02-05-2010, 01:00 AM
9.ford.5's Avatar
9.ford.5
9.ford.5 is offline
Originally Posted by alpha/omega
Ujoints dont need to be perfectly straight to run effectively. Dont turn it up too high or you'll fubar the oiling to the pinion.
no but the farther they get from straight the shorter their life span...at 0* a taken care of u joint should last pretty much forever
You guys are crazy if you think a driveshaft needs to be in a straight line with both the pinion yoke and tcase yoke.
thats not even possible unless you lowered your truck some incredibly stupid amount that put the pinon directly in line with the t-case output...and that would probably require some major frame/body/suspension modification haha
everything but how having a deeper diff cover will help oiling to the pinion.
You are saying an axle has the ability to push oil up hill?
they do actually...well they dont push it up, the gears carry the oil up, providing it is thick enough...a good 80-90 should carry pretty nicely...not only that but when the ring gear especially get spinning fast enough it tends to throw oil every where...the main problem with a large amounf of rotation on a diff is the fill/drain plugs are no longer accurate and it might take more or less oil to fill it
Old 02-05-2010, 09:26 AM
alpha/omega's Avatar
alpha/omega
alpha/omega is offline
Im going to be nice.
Old 02-05-2010, 09:31 AM
mark a.'s Avatar
mark a.
mark a. is offline
I used a 90* elbow to raise the oil level in this old Dana 60 I used to have under my truck before I switched to the 70-U.
Old 02-05-2010, 09:38 AM
mark a.'s Avatar
mark a.
mark a. is offline
I also put a front Dana 60 oil slinger in it when I was changing gears. There was enough room in the shim pack to get it in. It holds the oil up in the pinion bearing if you have to tip in a lot.
Old 02-05-2010, 09:41 AM
alpha/omega
^^ now were talking.
Ive got slingers on my front and rear pinion and neither of them are at an extreme angle.
Old 02-05-2010, 10:56 AM
73 ford guy's Avatar
73 ford guy
73 ford guy is offline
Some guys think if they run a 1410 ujoint they're invincible and will run at any angle( had this debate many times not naming names) Haha not the case. Though it will run at a higher degree but in a truck like mine with a 21 degree shaft angle is that gonna last uhhhhh yeah NO! But with my cv and 1350 joints 10.5 degrees on each joint in the cv I think that's a little better.. But I'm just guessing right...
Old 02-06-2010, 12:40 AM
9.ford.5's Avatar
9.ford.5
9.ford.5 is offline
whats your problem? i wasnt trying to single you out or call you out or anything i didnt even realize all those quotes were you until i posted haha...
dont be nice...say what you think you need to...im a brutally honest person if i got something to say i say it, so...lets hear it
Old 02-06-2010, 08:44 AM
alpha/omega
my interweb GF might get mad and you might cry.
Old 02-06-2010, 09:06 AM
dragogt's Avatar
dragogt
dragogt is offline
In other word he'd be spending time with the band...
Old 02-06-2010, 01:59 PM
captain p4's Avatar
captain p4
captain p4 is offline
a "winner", if you will
Old 02-06-2010, 02:22 PM
dragogt's Avatar
dragogt
dragogt is offline
Yeah, but hes a wiener all the time...
Old 02-07-2010, 02:54 PM
9.ford.5's Avatar
9.ford.5
9.ford.5 is offline
who the hell are you guys talking about lol
  #28
Old 02-07-2010, 09:04 PM
dragogt's Avatar
dragogt
dragogt is offline
Alpha/ omega..
  #29
Old 02-08-2010, 12:43 AM
9.ford.5's Avatar
9.ford.5
9.ford.5 is offline
oh...i get the feeling he was a member here before? from the way he talks with some of the people on here?
  #30
Old 02-08-2010, 06:48 AM
dragogt's Avatar
dragogt
dragogt is offline
Quick Reply: Pinion Angle
