99 Ranger 4x4 Extra Cab Leaf Springs
We have a 99 Ranger that is an extra cab 4x4 question is can we take these leaf springs out and install them into a 1995 Ranger 4x2 Extra Cab?
We know that the F-150 4x4 springs are 3" wide and some of the 4x2 are only 2.5" wide. Didn't know if they made changes on the Rangers?
Both have same size 6' Beds
We don't have the 95 here at the shop top take any measurements.
Thank you in advance;
Ford Depot
Ford Depot
on
According to TheSuspensionKing.com, they are the same from '86 to '03 and measure 2.5" wide. TheSuspensionKing.com - The Suspension King's Product Line...
Drive shaft Ranger 95 two piece can we install one from 99 Ranger?
Thank you for your quick replies;
Question of the Day 1995 Ranger extra cab drive shaft was told it is a two piece and we have one from a 1999 extra cab 4x4 same 6' bed will these drive shaft work hoping it should be the same length and was hoping the spline count might be the same? Or we could take the one from the 99 and send it out to a machine shop to cut and weld then balance it.
Seeking some feed back don't have one to put next to each other yet.
Thank you in advance for the great advice.
rangersvt04
1983 - 2012 Ranger & B-Series
04-10-2007 09:53 PM
