Fuel Return Line Kits (and viton o-rings)
#46
This is very similar numbers to the articles I found...so the case for this 100psi guy isn't looking good! I suspect that the OEM specs for your 94 7.3 IDI is probably pretty similar to my 86 6.9 IDI. Anyone have any information that would suggest the specs would be different?
#47
Where did you get that info. that would mean allowable tolerances was 150 pounds difference so a matched set guaranteed not over 100 pounds difference could possibly be better. Now is that 100 pound guarantee to be 50 + or - 1900 or is it just within 100 of each other. I would have to assume it is + or minus- optimum pressures.
The link where I found the article is on one of my previous posts...
And yes, 1800 to 1950 is a tolerance of 150 but it also says that adding one shim adds 55PSI so I'm thinking it shouldn't be an issue to get them matched within 55PSI... meaning that within 100PSI isn't that great (but much better than the old GM guy was saying). And considering another member stated above an OEM spec of +/- 75PSI a person knowing what they are doing with the right equipment shouldn't have an issue getting them less than 75PSI of each other.
That being said though... in a real world application, if we match one set of injectors within 75PSI and another set within 100PSI... Is it really going to make a difference?
#48
#49
#51
#52
I was told that new Delphis range from 1750-1900 out of the box with the majority being 1800-1900. I have heard from numerous sources that remans from a place like pensacola are all over the map as far as pop off. I thought the G code injectors were a emissions injector for california only?
nate
nate
#53
I have heard from quite a few different that bb was at least as good if not better than g code something about the g codes were there because of epa reasons. (have no proof of this)
In my way of thinking on the old big cam cummins we had to use injsetors according to the cpl # of the engine which changed by pump calibration and valve timing. Then we matched the pop pressure with the correct injectors. AND if we changed the pump calibration we also went up a notch with the injectors.
So in my old (geezer) way of thinking it is more important for our injectors flow rate and pop pressure to be matched with our IP calibration and fuel setting then with each other for optimum performance. Or am I thinking all wrong.
And if each shim changes the pressure a consistant 55 pounds a machinist building custom shims could indeed get them matched to some very low numbers, this would be good if he knew what the numbers needed to be to match the individual pump.
#54
nate
nate
#56
nate
nate
The G code injectors are called for with the turbo and E code for the NA. Ford says the G's flow characteristic of the nozzle is tailored for the turbo charged engine. I have heard about the emission thing but not sure where it comes from.
#58
#59
nate
#60
The G codes suck! they have an awful spray pattern its not really o nice fat pretty cone its kinda a real skinny cone not quite a **** but not what you want from an injector in an idi, the tips are actually a little larger ny .005 if i remeber right but the pintle are shaped like this U as aposed to the BB codes which is shaped like this V the BB codes have a nice fat cone that idi seems to really like best, also G codes pop off at like 2150 were as BB pop at 1750-1900, i am actually getting him to experiment with mine, im getting my pop pressure set as close to 2300 as possible, if i dont like it then im going to go about 1600 next time, which is what A code injectors were set to, if thats not what i like then im going back to the stock BB pressure
