Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
how to identify my engine?
Old 01-31-2010, 04:17 PM
manyolcars's Avatar
manyolcars
manyolcars is offline
I need help with my engine but first I need to know what it is.
The truck is a 1988 Ford L-8000 with an 8 cylinder front sump Caterpillar engine that redlines at about 2600 RPM.
There is a sticker on the valve cover that has the number 0ZZ43319
I appreciate any help. Thank you
Old 01-31-2010, 05:57 PM
Big_Dom's Avatar
Big_Dom
Big_Dom is offline
The Cat website should be able to help you figure it out some way.
Old 01-31-2010, 06:36 PM
rbaker6336's Avatar
rbaker6336
rbaker6336 is offline
Probably a 3208
Old 01-31-2010, 07:12 PM
manyolcars's Avatar
manyolcars
When I got the truck I could reach in and bump the key to start it.
It ran well.
Now I have to work the throttle just right to start it,
it runs rough and makes an enormous cloud of white smoke.
Any ideas what is wrong?
Old 01-31-2010, 07:28 PM
rbaker6336's Avatar
rbaker6336
Check for fuel line leaks,sounds like it may be sucking air
also check for intank fuel pump
Old 02-01-2010, 11:50 PM
manyolcars's Avatar
manyolcars
thank you.
(message too short)
Old 02-14-2010, 11:15 PM
FESuperDuty's Avatar
FESuperDuty
FESuperDuty is offline
Sounds like an old 3208. As for the white smoke, does it smell really rich and burn your eyes? Your injectors may be dirty and not atomizing the fuel. The effect will be worse when the engine is cold.
Also, it could be caused by the ultra-low sulfur fuel we now have. The process used to remove the sulfur content also removes the lubricating properties from the fuel. This can cause premature wear in the injection pump and nozzles. I would run some really good fuel conditioner through it. I use Stanadyne fuel treatment in mine.
I am a heavy equipment mechanic, and one of my customers called me one day because he couldn't keep his diesel forklift running. When I got there, I checked the obvious, fuel filters, air filters, water in the fuel, etc. Everything looked OK. I asked him if he had been running fuel conditioner, and he said no. I gave it a heavy dose of Stanadyne and got it started. After about 20-30 minutes working the throttle, it smoothed out and ran fine.
What I mean by working the throttle is get it running, then throttle it up and let it idle down. Keep repeating this process for a little while. That will give the pumping mechanisms an other moving parts time to get lubricated.
Old 02-14-2010, 11:21 PM
FESuperDuty
Something else. If it is hard to start, it sounds like it may also be related to the low sulfur fuel. As you are cranking the engine the governor weights in the injection pump are supposed to open the fuel wide open for starting.
When the pumping mechanisms are suffering from a lack of lubrication, the weights may not be able to overcome the sticking, making it hard to start. Here again, hopefully the fuel treatment will help free things up after it has run awhile.
Quentin10
05-27-2014 03:04 PM
chard17
1997 - 2003 F150
03-25-2014 06:10 PM
VocaTexas
08-12-2013 07:07 PM
Rickys88
18
11-23-2003 02:26 PM
moneypit2
1978 - 1996 Big Bronco
06-12-2000 04:13 PM
Quick Reply: how to identify my engine?
