Front door speaker size?
As far as depth, my door speakers are about 3.25" beep and they fit in with no problems. The only problem you may run into is where the tweets are mounted on the face of the speaker, they may be too tall. Look for a slimmer design on the face to clear the integrated grille on the panel.
A tip if you have tinted windows though, a simple fix to keep the speaker from possibly rubbing on the window is, simply put some washers between the speaker and the door to space it out and keep it from scratching your tint.
Wish I had known that before the person that put everything together in my old car.
Thanks for the info.
Now on an unrelated to speakers note: I just found some new doors with power windows. Whats the chances the wiring harness is in my truck.(1990 f250) I have manual windows and locks. The power doors are in much better shape and I would sure like to use them. Maybe I should "New Post" this.
-Jared
-Jared
uhm it wouldnt be to hard to make them work.... there is a place in the fuse box that prolly has a fuse in it already just run ur hot wires from it... then run a hot wire from the drivers side door to the passenger side door switch and tie it with the hot wire so u can opperate both windows from the drivers side....
hope that makes sence to u
Check out Crutchfield: LCD TV, Car Stereo, Home Theater, Speakers, Plasma TV they have a web config tool that will tell you what you can fit in your truck.
