1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
tow mirror bulb replacement
Old 01-27-2010, 11:37 AM
in heat's Avatar
in heat
in heat is offline
I have an 08 with tow mirrors and I need to replace the bulb on the passenger side , how do I get the mirror apart? I really don't want to break it?
Old 01-27-2010, 12:13 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
between the glass and the frame on the outside edge you can use a small screwdriver to release the clips that hold the light housing, which will slide forward.
here is a pic with the area circled
Sam
Old 01-27-2010, 03:08 PM
in heat's Avatar
in heat
in heat is offline
behind the mirror?
Old 01-28-2010, 01:48 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
to the top
Old 11-06-2010, 12:48 AM
woodsters's Avatar
woodsters
woodsters is offline
Would this be the same on a 2010 F250? Do you push on the clips?
Old 11-06-2010, 05:17 AM
scraprat's Avatar
scraprat
scraprat is online now
Received 2,502 Likes on 1,307 Posts
It's not that hard guys, walk away from the computer to your truck. Turn the mirror all the towards the truck and peek in there, use a flash light for better light. Poke and pop it out, change the light and push back in. sdetweils pic is right on.
Old 11-06-2010, 07:33 AM
sdetweil's Avatar
sdetweil
sdetweil is offline
yep, still the same.. one clip on the inside holds the whole housing, which slides forward off the mirror
sam
Old 11-06-2010, 09:25 AM
Pappy1911's Avatar
Pappy1911
Pappy1911 is offline
Many thanks for your help folks... I'll go out side and have a look. Another problem, all the searching for mirror part numbers only show the standard mirror, not the tow mirror. Any help with the part numbers? My problem is the amber lens is broken out and the local Ford dealer cannot find the tow mirror parts....
Old 11-06-2010, 04:05 PM
woodsters's Avatar
woodsters
Someone on another forum mentioned turning the mirror not only in towards the truck but up as well. Went and did that and was able to see the clip without a flashlight. It's a big metal clip. Popped it out with a small flat head screw driver.
Old 11-06-2010, 04:15 PM
Pappy1911's Avatar
Pappy1911
Bingo..I see several places that appear to be clip areas...will try to remove at a later time.. Thanks again all.
Old 11-06-2010, 09:13 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
The clip is about 1.5 inches wide, directly in line with the lens
Sam
Old 11-07-2010, 03:51 AM
woodsters's Avatar
woodsters
Yep...was an easy fix...luckily all that happened with mine was my wife hit something with the mirror and it caused the mirror to fold in. She noticed a day or so later that the light wasn't working on it. When I popped it off yesterday, the bottom bulb had came out of it's socket. Pushed it back in and works like new. Unbelievable how hard it was to try and find information on this. Didn't see info in the owners manual about it either.
Old 10-12-2011, 02:21 PM
TXtinct's Avatar
TXtinct
TXtinct is offline
You'll shoot your eye out
Anyone know what type of bulb this takes?
Old 10-12-2011, 02:51 PM
Pappy1911's Avatar
Pappy1911
They are probably LEDs....
Old 10-12-2011, 03:49 PM
TXtinct's Avatar
TXtinct
TXtinct is offline
I don't think they come from the factory with LEDs. I'm guessing 168 or something like that.
Quick Reply: tow mirror bulb replacement
