What would be some symptoms of a bad map sensor?
Old 01-26-2010, 09:54 PM
97FRD1TN's Avatar
97FRD1TN
97FRD1TN is offline
My truck has been feeling sluggish lately and the cel came on.So I put it on the scanner and it brought up malfunctioning map sensor.So first of all i just went to the junkyard and got a used one but it didn't make a difference and the light came back on.So the truck runs fine at idle,but it just has an occassional misfire out the exhaust.And when I accelerate hard from a stop the truck just feels flat,and no power,it will cruise fine down the road but just sucks the gas and is a gutless wonder right now.So would all this be the cause of a bad or malfunctioning map sensor? Thanks guys.
Old 01-27-2010, 07:00 AM
EPNCSU2006's Avatar
EPNCSU2006
EPNCSU2006 is offline
It could be, but also check the vacuum line to the sensor and check the condition of the wiring back to the computer. MAP sensors aren't cheap, so make sure that the sensor is the problem before throwing down the money for a new one.
Old 01-27-2010, 07:10 AM
Lazy K's Avatar
Lazy K
Lazy K is offline
I would check the fuel pressure and also check for a restricted exhaust.
Old 01-27-2010, 07:38 AM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,165 Likes on 920 Posts
What was the error code(s), by number, you got?
Old 01-27-2010, 01:28 PM
97FRD1TN's Avatar
97FRD1TN
97FRD1TN is offline
I don't recall a error code with numbers.I'll have to rescan it,but I do know that the exhaust is not restricted and the fuel pressure regulator didn't take a crap.I do know that map sensor's are not cheap,but i would rather it be that then trying to chase crap down.
Old 01-27-2010, 01:45 PM
rla2005's Avatar
rla2005
Use this link to view what the frequency output of the MAP sensor should be: Ford Fuel Injection Manifold Absolute Pressure Sensor (MAP)
You should be able to use a DVM that can also measure frequency to verify if yours is within range.
Old 09-04-2014, 06:15 PM
Linda Packwood's Avatar
Linda Packwood
Linda Packwood is offline
my ranger is fine when idling but when put in gear it is idling faster,any clues to why it might be doing this will be greatly appreciated
halleva
06-09-2017 09:05 PM
jakesterrocks
08-01-2016 12:09 PM
abbydane2
02-25-2016 08:17 PM
winklershop
11-25-2014 10:21 PM
dirtynorth49
57
01-20-2012 03:11 AM
Quick Reply: What would be some symptoms of a bad map sensor?
