Connecticut Chapter Join Chapter, Leader:
E-450 tranny service?
Old 02-12-2010, 06:44 PM
StreamlineGT's Avatar
StreamlineGT
StreamlineGT is offline
2005 E-450 with a V10 and what I think is a 4R100. It has 31'XXX miles, and my father is asking what should be done. This is a Class B+ van front motorhome. Flush? Drain'filter, fill?
Thanks (not interested in asking the masses)
Brendon
Old 02-16-2010, 05:45 AM
gbroehl1's Avatar
gbroehl1
gbroehl1 is offline
Its probably the 5R100 if I had to guess. You could certainly do a drain/filter job. A flush would probably be overkill for only 31k miles. The filter is probably 10-12 dollars along with a gallon or two of ATF and you should be all set.
Old 02-16-2010, 02:08 PM
7.3 Rocket's Avatar
7.3 Rocket
7.3 Rocket is offline
Greg I believe it's a 5R110 not a 5R100. At least that's what our 06 has.
Old 02-16-2010, 02:12 PM
gbroehl1's Avatar
gbroehl1
gbroehl1 is offline
That's what I meant. Thanks
Old 02-16-2010, 03:05 PM
Aerocell4x4's Avatar
Aerocell4x4
Aerocell4x4 is offline
Diesel Van Enthusiast
And there are two 'filters.'
One is a suction screen which is R&R'd by dropping the transmission pan.
The other is a bypass filter 'toiletpaper' in a bowl alongside the transmission.
Note that that bowl can be a tough nut to unscrew.
Old 02-18-2010, 01:00 AM
larry_kruzan's Avatar
larry_kruzan
larry_kruzan is offline
Tranny IDs
I have a 09 E350 V10 and the VIN shows that it has 5R110W-Hi Torque according to the manual, code "B".
What is the difference between the 5R115 and the 5R110?
Thanks, Larry
Old 02-18-2010, 02:51 PM
Aerocell4x4
Hi Larry
The answer is torque capability, and apply the same to your 115.
I forget where I came upon this:
As for the 110, that represents 1100 lb-ft, but that's AFTER the torque converter multiplies engine torque by 1.9:1. That means it can take about 580 lb-ft of engine torque.
190 jerry
1999 to 2016 Super Duty
13
07-27-2012 12:49 PM
yme450
05-15-2010 07:04 PM
bumper
Modular V10 (6.8l)
08-30-2005 12:28 PM
Busguy
10-06-2003 12:33 PM
HiTech
1997 - 2003 F150
06-14-2002 09:11 PM
Quick Reply: E-450 tranny service?
