Spartan Tunes on a Mac
Well, I have a Mac with VMware Fusion installed on it to run Windows XP. I did not have to buy Windows as I used my old install disks from my old PC. VMware will run you $80 if you download it from their site but it's $68 if you buy it from Amazon. Windows 7 Home Premium will run you another $180 from Amazon. I like running VMware rather than bootcamp since I can run both OS's at the same time.
It's not as bad as you think. If you can borrow your friends PC for about an hour you can get done what you need to and never look back. Once the tunes are loaded on the memory card you don't need to connect to the PC anymore. I think that would be a lot simpler than installing a second operating system that you will rarely use. Just my 2 cents.
If its an Intel, which if bought in the last 2 years new it is, you can buy Parallels or VMFusionware for around $70. Then you will need an Install Disk for Windows XP or 7. But like Brandon said, it may just be easier to borrow a friends computer, unless you have the need to run Windows on the Mac. Unfortunately in my line of work all the hospital systems use Windows so I need to be able to run the occasional program, so therefore I have it. Mac's can run Windows faster than some original PC's, but unless you need it for other reasons, the cost far outweighs the benefit.
I have an old dell laptop, Im talking 5 years or so. Will that work for spartan tunes?
So are you saying I can load all the tunes on my memory card once and be done? I was under the impression if I wanted to change tunes I would have ot go back to my computer to do so? I m a little confused here. If I only needed a pc once then its a whole new ball game. I assumed I would need it for everychange of the tune.
Thanks for the help, the more I talk about it the closer I a to ordering it
SJM
SJM
SJM
SJM
It is not compatible..... The only time you need a windows based computer for the DashDAQ is when your updating the firmware. For that all you have to have is access to a IBM compatible computer or the software that will allow you to operate windows software on your MAC. For all the files on the DashDAQ, themes, sound, splash screen and config file all you need is an sd card reader/writer. Doesn't MAC have these on their computer, or can you purchase one.
When updating the firmware, including downloading the software, installing it on the computer, the total process only takes about 15 minutes.
Tech Support - Firmware Update 2.1.2-1949 / Updating Your DashDAQ
Thanks for the help above guys. Ill shoot you a pm brandon as I get closer to doing it. I have a card reader writer for my mac. So im guessing I will be ok. When I order the DD it should have the lateset frimware on it I would assume.
Im gonna do some more poking around but Im getting ready to do this!!
Thanks for the help again
SJM
SJM
