is my truck lifted or factory?
I looked under the rear of my truck and didnt see any blocks, but, the P.O. could have put arched springs in I figure. just wondering if its factory or if its already been lifted a little. eventually I want to lift it more, and want to make sure its done right. heres a pic of my 79 f150 4x4 with 31" tires.
The "Highboy" does not have a "factory lift". Ford just changed the ride height slightly for the 77.5 model. The Highboy is only about 2 inches taller than the 77.5-79 models. They LOOKED like they had a lift kit when compared to a 3/4 ton Chevy of the same era. But, they are barely any taller than the "Lowboy" models.
a factory 4inch block is a lift of sorts what i was getting at as if you look at the highboy compared to this 1/2ton
Also, nearly all "Highboys" which claim to be "stock" or "factory lifted".........have actually been modified in some way. I'll see if I can find some pics......
I am going to try and link some pics from another site. Not sure if it's going to work though....
Anyways, here is a truck that is for sale on Rustfree Classics. The truck is advertised as a stock height 75 Highboy
But, if you look close.....
...those are aftermarket lift springs....with ANOTHER extra leaf added to the bottom (not sure what they were thinking)
And, check out the back...
....those are NOT the factory blocks.
So, this "factory lifted" truck was actually lifted by someone else.
The truck is advertised as a stock height 75 Highboy .....But, if you look close.....those are aftermarket lift springs....with ANOTHER extra leaf added to the bottom (not sure what they were thinking)
