351m-c6 to aod
Old 12-25-1999, 12:37 PM
Trail_Rider's Avatar
Trail_Rider
Trail_Rider is offline
351m-c6 to aod
Old 01-04-2000, 09:01 AM
frankie's Avatar
frankie
frankie is offline
351m-c6 to aod
i've got a 351m w/c6 in a 77 f100. from an earlier question, someone suggested changing to an early 80s tranny with aod. is this possible? will the 80s tranny w/aod bolt up to the 351m?
if so, are there any modification needed?
Old 01-04-2000, 09:54 AM
Boss_358's Avatar
Boss_358
Boss_358 is offline
351m-c6 to aod
As far as I know Aod trannys came out in the 80's and the 351m/400 was only produced a couple of years in the 80's until it was dropped. The only Possible donor I could think of is to find a later model 460 and see if you can find out if Ford ever mated an overdrive tranny to it since the 460 has the same bolt pattern. Somebody else on the forum should know some more about it than I do.
Old 01-04-2000, 10:29 AM
deleontow's Avatar
deleontow
deleontow is offline
351m-c6 to aod
Checking through Hollander interchange, I could not find any year in which a 460 came out with an over drive trans, except the E4OD, which is electronic and would not work for you. All of the AOD were for small block engines only
Dave
<a href="http://members.aol.com/deleontow/auto/index.htm">http://members.aol.com/deleontow/auto/index.htm</a>
Old 01-04-2000, 10:58 AM
frankie's Avatar
frankie
frankie is offline
351m-c6 to aod
and the quick response. i've been told by a garage that there was no practical way to have an od in my truck. i might as well forget about it.
Old 01-05-2000, 02:25 PM
sam_1's Avatar
sam_1
sam_1 is offline
351m-c6 to aod
Someone makes a controller for the E4OD.
If you had that, a 460 E4OD should bolt up to your 351M.
Old 01-06-2000, 01:49 AM
V10 MAN's Avatar
V10 MAN
V10 MAN is offline
351m-c6 to aod
Jet a copy of Truckin mag. A company named JET has kits to use an OD tranny. Or jetchip.com
Old 01-06-2000, 06:25 AM
jowilker's Avatar
jowilker
jowilker is offline
351m-c6 to aod
V10, I just did a quick check at their site, their catalog starts at 86 and only for the 302. I don't believe that any help for this request is there.
John
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
Old 01-06-2000, 11:23 AM
bc's Avatar
bc
bc is offline
351m-c6 to aod
I think you can do anything if you want to spend enough money. If it is true that the E4OD will bolt up to the 351m-400 then I think this site will be helpful.
<a href="http://www.baumannengineering.com">http://www.baumannengineering.com</a>
Old 01-06-2000, 12:23 PM
jowilker's Avatar
jowilker
jowilker is offline
351m-c6 to aod
BC, You are quite correct in that anything can be done for enough money. The big problem with most of us here is we have champagne tastes, and beer budgets.
Thanks for the link.
John
66 F100s
bradphx
67
01-10-2024 06:12 PM
Aerostar
01-14-2015 03:16 AM
miko6810
Modular V10 (6.8l)
06-04-2014 06:14 AM
1978 - 1996 Big Bronco
05-25-2002 03:08 PM
broom
11-24-2001 12:46 PM
Quick Reply: 351m-c6 to aod
