5.4
hello, i have a 97 f-150 it had a 4.2 v6 with auto trans. i am putting a 5.4 v8 with auto trans,that came out of a 2000 f250. i have both trucks that have all the wiring from both trucks,can you tell me what do i need to do to get all the wiring to interchange so that everything works? thanks so much for anything you can tell me.
You're definitely gonna need the PCM, and the two primary harnesses (one connects to the motor, the other to the transmission. On the V8, they're connected in a bracket on the top passenger side of the firewall, and the PCM connector is on the passenger side firewall behind the battery. The PCM itself is inside the truck opposite the connector at the firewall. Beyond that, I'm not sure how any of the other stuff in the truck will be affected....
thanks, i know it will be time consuming. i thank that is what im going to need to do in order to have everything working as normal.thanks again.
