Custom '08 Fender Vents From Billet Badges.com
Old 01-02-2010, 02:53 PM
pbeering's Avatar
pbeering
pbeering is offline
About two wildfires, and some months ago I contacted Steve Smart from Billetbadges.com about creating some custom vents for the '08. He figured out the tooling and after some exchanges of artwork and concepts:
Step 1 Remove existing vents, which are chromed plastic and held in with clips.
Old 01-02-2010, 02:55 PM
pbeering's Avatar
pbeering
pbeering is offline
Once the old vent was removed, the wiring could be completed. Note that heat shrink connectors were used since this will be in the salt.
Old 01-02-2010, 02:57 PM
pbeering's Avatar
pbeering
pbeering is offline
After the paint underneath was cleaned with a mix of alcohol and water, dried and warmed with a heat gun, the new machined vents were installed.
Old 01-02-2010, 03:00 PM
pbeering's Avatar
pbeering
pbeering is offline
These incorporate the Whelen LINZ6, a 6 LED linear head with very good off axis warning. They are very bright.
For those in the fire service or other emergency vehicle applications, Steve Can customize these to reflect your department, unit number, etc.
Old 05-30-2013, 04:08 PM
robert_l_ross's Avatar
robert_l_ross
robert_l_ross is offline
First off brother - those are SICK!!
I've contacted Billet and asked for a similar set, but with the first line reading the factory "EXCURSION" font then the middle line of "6.8L V10".
Can you tell me where you found the lights that fit inside that badge - and did you have to drill new holes in the fender to get the wiring through, or did the wiring fit through an existing hole under the original badge?
Thanks!!!
Old 05-30-2013, 04:16 PM
pbeering's Avatar
pbeering
pbeering is offline
These fit the 6.4 diesels (2008-11) which have functional vents. (No cutting) the Billet product would fit your Excursion, but you will have to cut a hole for the light and wire.
The light is a Whelen LINZ6 which is switched seperately to allow side only warning. The light head is attached to the billet vent with sensor safe RTV.
Old 05-31-2013, 01:31 AM
robert_l_ross
OUCH...not ready to commit to a vent-sized hole just yet. ...wonder if these surface-mounted to the badge would work....
http://www.whelen.com/pb/Automotive/...-LED_Light.pdf
Old 05-31-2013, 07:00 AM
pbeering's Avatar
pbeering
pbeering is offline
The Vertex has a bigger diameter than the LINZ6, but anything can be machined......
You might consider installing the Vertex in the front turn signal, or Whelen recently released a new flush mount head that you could mount on the bottom of the mirror.
Third approach would be to upgrade the mirrors to the newer style towing mirrors and mount a lamp in the marker light area.
Old 08-08-2014, 10:01 PM
jaygagne101194's Avatar
jaygagne101194
jaygagne101194 is offline
I noticed you used automative red tape on the back. Is it because you broke the clips? Does using only the red tape hold it to the vehicle? I have a 2006 F350 and want to do the same but without a LED installed.
Thanks.
badger_hound
26
08-30-2011 03:47 PM
harrisford
User Gallery & Picture Display
07-16-2011 08:09 PM
Kusto
16
09-09-2009 12:10 AM
byro01
06-24-2009 09:12 AM
Quick Reply: Custom '08 Fender Vents From Billet Badges.com
