1976 F250 Ignition Switch Housing
Old 12-31-2009, 03:29 PM
F250Stu's Avatar
F250Stu
F250Stu is offline
Hey comrades. My ignition switch was getting real flakey, so I pulled it out thinking a replacement would be fairly easy to find. Not so, all the ignition switch housings my truck called for did not match what I pulled off. I have a 1976 F250 Custom Cab 4x4 - although the "F250 Custom" emblem on the cowl suggest it's a 1977. It has a 390-2V in it which also suggests it's a pieced together truck, I think.
Anyway, the switch housing I pulled out had this part number: D6TB-11572-AA.
I checked the part number decoder on this site and it seems to match up. But, can anyone tell me what vehicles this switch housing came on originally? Was it the E250 Van?
Old 12-31-2009, 03:43 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,707 Likes on 1,381 Posts
I am not too familiar with those year trucks, but is there a function problem with the replacement switches(they won't physically fit or the terminals are wrong) or is this a cosmetic problem(the other switches will work but they don't look the same)?
Old 12-31-2009, 10:02 PM
F250Stu's Avatar
F250Stu
F250Stu is offline
It's a functional problem - the electrical plug will not fit (it's not the same shape) as the switches I've been sent, so far. The terminals do not match, either.
I had a little luck finding a replacement via NAPA's Online Search. I punched in the part number I posted earlier using the Part Number search with "interchange" selected and up it came. Here it is... If anyone knows what this switch came on originally, I'd still like to know.
I tried to put the URL here, but it didn't work; so, here's how I found it:
1) go to http://www.napaonline.com/Search/Default.aspx
2) typed the part number into the Part Number Search
3) click "Interchange"
4) click the Search button below it.
Old 12-31-2009, 11:29 PM
Franklin2's Avatar
Franklin2
I can't get it to work for me. I thought if you had the Napa number or the Echlin or whoever made it number, you could find out some more info.
Old 01-04-2010, 09:46 AM
F250Stu's Avatar
F250Stu
F250Stu is offline
Thanks for your efforts to help, sir. It is much appreciated. I probably left out a step somewhere...
All's well that ends well, right? I drove the truck in to work today.
Thanks.
gaffmedic
04-05-2017 02:15 PM
1976F-150Custom
12-02-2016 03:37 PM
F250kyle
04-27-2016 09:05 PM
Yojacky3
18
01-19-2016 07:16 AM
transworldmotors
04-05-2006 01:23 PM
Quick Reply: 1976 F250 Ignition Switch Housing
