BAD BATTERY
BAD BATTERY
MY 2009 SUPERDUTY F350 V10 HAS 9000 KMS.ON WENSDAY WHEN I LEFT HOME IT DIED ON THE SIDE OF THE ROAD.IT DIDN T TURN OVER BUT HAD POWER.SO TO MAKE ALONG STORY SHORT TOWED TO FORD AND THEY HAD TO REPLACE THE BATTERY.IS THIS A NORMAL PROBLEM?IT LOOKS REALLYBAD TO SEE A NEW TRUCK ON THE BACK OF A TOWING.
I had the same thing happen to my '99 F250 Superduty. I replaced the battery 11 months ago with a OEM battery purchased from the Ford dealership. I use the truck as my DD. I went to go to work a couple days ago, and the truck would only click and not turn over! Long story short, I had a cell go bad in the battery. Dealer replaced it free of charge , and now the truck runs great again.
Years ago, I put a good quality new battery in a '72 Chevy camaro and had a cell go bad within 1 WEEK!
So yes, new batteries can go bad.
It is possible it is just the battery. Being a 2009 and without knowing i't's life on the lot and how long. If the truck was built in late 2008 or has been on the lot for quite some time the battery could have had a early demise. The battery only needs to go completely dead a few times or less to destroy a considered "new" battery.
changed the battery in my '08 allready, was barely cranking over on a 15 degree morning. put a diehard platunum in it now it cranks over like crazy in the cold weather. i used to work on gm vehicles for a living and once in a while would see a new delco battery defective, it happens once in a while. also agreed letting a automotive battery stay undercharged will ruin them, it begins the sulfation process. auto batterys like to stay fully charged.
I wouldn't sweat it. I've had car / truck / motorcycle batteries last years.. and others crap out quickly.
I just replaced my 2 yr old NAPA batteries in my F250 6.0 with a set of fresh Wal-Mart bat's. $150 for the set. 3 yr replacement. 8 yr prorated. On a diesel, if they last 3 yrs, I'll be happy.
I've got a buddy who has an '08 F-150 and his factory battery already went south. Sure sounds like some just don't want to last too long - at any rate, if you drop some money on a decent battery now you won't have to worry about them for years. I put red-top optimas in my '02 years ago and haven't looked back. I've had one die after the truck sat for a few months, slapped it on the charger and it is still going strong.
Good Luck.
Good Luck.
bought of a set of napa premium golds for the "great white shark" in dec 08. had to get new ones under warranty this dec 15 09. full coverage so no $. they tried telling me it was the trucks fault.the first set started it, but if it sat for 2-3 weeks it struggled. the new set cranks faster at -20 than the first set did with a hot engine. kind of makes me think it was an old stock battery ot it had a slight short right from day one. checked the alt the other day 14.1v(brand new VOM) so i'm thinking its not the truck
You haven't looked at the 99 - 03 deisel forum then...hehe Couple there already... along with the "Hard starting when cold" threads.
