You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
pretty simple question. I have the stock up-pipes (as far as I can tell) on my truck, and am debating whether or not to replace them with the bellowed up-pipes. I have no visible exhaust leakage, and I was just wondering whether it makes a huge difference replacing the stock up-pipes if they are not leaking yet...
so should i spend my money on a new set of up-pipes or on a limited slip rear diff?
well as far back behind the engine as I can see i do not see any soot....are there other signs of leakage that I should be looking for? is it worth the 500 for new ones if i cant see a significant leak?
if there not leaking dont worry about it right now..if you got $$$ too burn..then go for it..you dont get any extra power from putting them on..i been seeing quite a few DI bellow for sale in the classifieds over on PSN..i got a set of new IH pipes over there for $100 a couple years ago..
__________________
Early 99 7.3 F350 auto,TN T-4 mount with a s467 for air,SRP 1.1 for oil,H-11 stud's,"NEW" alliant 315/200 hybrids, all supplied by unlimited diesel..shimmed 910's, DI push rod's, full fuel with a fuel lab 4202,TSD sump...tuned by Gearhead..i cant wait to drop her in the truck... http://inlinethumb43.webshots.com/50...200x200Q85.jpg
I have a running list of long term maintenance/fix goals for my truck - the up pipes were on it and I had the same questions you did. Btw, mine were leaking, but not terribly. I plan to drive and maintain my truck for a reasonably long period of time - I asked Clay at Riff Raff if he thought it was worth the money b/c $400+ is a little steep. His response was balanced and intelligent. You can repair the stock donuts, but at some undetermined time they will fail again. If may be 50k or 5k miles and then you'll need to pull the turbo, etc. . . .the cost of the part makes up for the cost of the repair multiple times and there is some piece of mind in knowing that your truck is well set up. In most circles people would think I'm strange for having a running list of maintenance/ fix/ improve goals but here it seems more the rule than the exception. With it comes no guarantee, but confidence in the service my truck will provide. Hell - that was long winded - sorry.
I didn't see any soot on my up pipes untill I got my DP TUNER. I couldn't make smoke before the chip. I think my pipes were leaking before, but I couldn't see it.
__________________
RICK, PAA MEMBER #4
2001, F-350, DRW. CC. LWB, 4X4, LARIAT,
MODS: 6637 W/Pete's cover, BTS-TRANS, DP-TUNER LIVE, MBRP 4" SS, Isspro 3 gauge kit, TN-BB turbo, Bellowed up pipes, HPX, TRU-COOL cooler, SS Stage II injectors, and the Chris-fifty.
Turbochargers rely on exhaust drive pressure to build boost.
If there are any leaks, the boost will build slower and not as high.
The more boost is needed the faster that leak will bleed off pressure.
It's never an issue at light load, idle, etc.
The real problems begin when the engine is really needing to make some power, such as pulling a trailer up a mountain pass.
That is where the big difference will be.
I have bellowed pipes.
On the PHP 80hp tune, I stomp on the throttle, exhaust belches a large puff of black smoke, then the turbo spools up NOW and the smoke clears as the truck takes off like a scalded dog.
__________________
Dan
1999 F550 4x4 ZF6 pulling a Cedar Creek 36RLTS. Lotta mods.
1999 VW Jetta TDI 5speed stick, Titan 520's, CCV, EGR, CAT.
2000 VW Passat 1.8t Tiptronic. ZZOOOOOMMMM!!!
1996 Audi A4 Quattro. Unstoppable in the snow and ice.
You cannot explain or explain away the power of God.
i cant see soot on my pipes but i know they are leaking, i reached way in behind the turbo and felt the pipes and my hand was covered with soot. 2 reasons that i knew they were leaking, 1. when i would let to truck warm up i could smell exhaust in the cab, 2. i have noticed the my boost pressure was slowly going down, not having the max number i used to.
__________________
jeremy
PAA # 86
00 F250 136k handshaker 4x4 zoodad 6637 cold air ccv aih delete ww foil delete 6.0 intercooler turbo back stacks overboost s.shpx 140 idm schaffers engine oil fumoto hutched and harpooned 203* dp tuner full syn fluids traction bars blisten shocks
well as far back behind the engine as I can see i do not see any soot....are there other signs of leakage that I should be looking for? is it worth the $500 for new ones if i cant see a significant leak?
If you end up deciding to do it you shouldn't have to pay this much...
These Up-pipes are on my first to do list when I get back to work, I just got a very very small area after the BB on the pipe where Pete duckfan pointed out to me at RRE09 so they will be going in at some point in the near future. No noticeable power loss or smell but I'm doing them because they will need to be changed out sometime, might as well do it now before the price goes up again, and they will..Clay's who I'll be calling.
__________________ Mike's 03 F-250 7.3 CC SB XLT 4x4 Auto and just joined the 200,000 mile club and counting. PAA#26 Wife's: Whoops, I mean an 08 (Explorer) Eddie B. 4.0 v6 4x4 91,000 http://www.ford-trucks.com/forums/si...ic511779_3.gif
Don't be sorry.....there's absolutely nothing wrong with long term planning. The trouble many Americans get into these days is rushing into something without thinking of all the ramifications.
Dave Ramsey says "a well informed and patient man always wins". Stay the course!
__________________ Les
2002 True Blue F350 Ext Cab 4x4 7.3 PSD SRW LB
Rhino Line; 4" BDS Lift; Bilstein Shocks; Centerline Rims; Racor Ext Fuel/Enviro Bypass Oil/Magnafine Trans Filters; 8 Autometer Cobalt Gauges; AIS; Toyo 315/75R16 ATs; Banks Monster Exhaust, Mag-Hytec Trans & Rear Diff Covers; BTS; ATS: AIH Delete; Spearco CAC; DP Tuning; DI SS Ups 30 Yr USAF Vet
thanks guys, I said 500 beacuse when i get them i plan on getting the ceramic coating. Also i'm tryin to figure out whether to use the money for a limited slip rear end or on the up-pipes. I live in eastern WA, so its a tad annoying to have only one wheel spinning in the snow...but its not something that i cant deal with if the up-pipes are a better investment
