New member here! Have a few questions!
Old 12-26-2009, 04:25 PM
sjahnke's Avatar
sjahnke
sjahnke is offline
I learned that lesson the hard way on my first truck, a 1951 F-1.
Old 12-26-2009, 05:49 PM
CharlieLed's Avatar
CharlieLed
CharlieLed is online now
Tom,
First off, welcome to the FTE forum!
If I had that truck and it was running I wouldn't touch it. If you REALLY want to build a hot rod F100 then start from a pile of parts and build it from the ground up...keep this one intact. There is no reason not to use the Ford frame, unless your just into pain. There any many frames available and a wide variety of IFS to make them ride and handle like a new truck. The aftermarket is full of fenders, grilles, running boards, beds, you-name-it. Start with a frame, add the IFS and rear suspension that you like, build a nice Ford small block engine, bolt on a good cab and sheetmetal, and you'll have a nice Ford truck that you can be proud of.
Old 12-26-2009, 11:22 PM
Toms53Ford's Avatar
Toms53Ford
Toms53Ford is offline
Thank you for all the responses. Sorry I didn't get back to you all sooner!
I know where Robbin's is, I go to community college with a friend that lives there.
I have access to a lift but I won't til the beginning of January.
How easy would it be to get a NOS frame? I would like something that's strong enough to handle the 400+ HP that's going to come from the stroker. Would you guys like some pictures of the frame so you can better judge what it really is? I have no idea what a 53 frame looks like so I can't tell for myself.
Old 12-27-2009, 08:54 AM
tacson's Avatar
tacson
tacson is offline
Tom,
Just let me know if you interested and I will give you my friends contact info. Private message me if you want his info. He knows a thing or two about 53-56 F100's especially frames.
Old 12-27-2009, 10:01 AM
AXracer's Avatar
AXracer
AXracer is offline
Tom, I'm just down the road from you in Durham. My 56 Panel has a 400 CSB and T-56, 9" with stock chassis. I'm also a national level autocross racer with a strong drag racing background. I'd love to take a close look at your truck and talk over various options before you get too deep into it. You can email me at teampointless(at)nc(dot)rr(dot)com
Old 12-27-2009, 10:48 AM
Julies Cool F1's Avatar
Julies Cool F1
Julies Cool F1 is offline
HI Tom!
Happy New Year and Welcome to FTE!
Old 12-27-2009, 03:42 PM
Toms53Ford's Avatar
Toms53Ford
Originally Posted by tacson
Tom,
Done and Done! Thanks y'all. I'll get some pictures posted of the truck frame and cross members today or tomorrow.
Old 12-27-2009, 07:59 PM
Earl's Avatar
Earl
Earl is offline
Originally Posted by jniolon
If I remember correctly the numbers are on the right frame rail toward the front... and I think on the top of the rail....
john
John hit it on the nail. Here's a photo of a typical frame rail stamped VIN and a second photo with a red arrow showing where I found it.
Old 12-28-2009, 05:38 AM
Toms53Ford's Avatar
Toms53Ford
Judging by just that picture, it's not the original frame.
Old 12-28-2009, 10:19 AM
sjahnke's Avatar
sjahnke
sjahnke is offline
If you do indeed have a 3/4 ton GM truck frame it should be able to handle your stroker motor with no problem because GM put big block engines in 3/4 ton frames with no problems. I used to have a 1973 3/4 ton Chevrolet truck with the factory 454 and Turbo 400 trans. Fun truck.
Old 12-28-2009, 03:32 PM
Earl's Avatar
Earl
Earl is offline
Tom, I should have written a more clear reply. My truck is a 1956 F-250 and has a different frame than a stock 1953 F-100 would have. I posted the pictures to give you an idea of where the VIN is stamped (they should be in roughly the same place on both our trucks) and what it might look like when cleaned up with a little degreaser and a wire brush. Sometimes it is very hard to find your VIN stamp with road crud and oil covering it. Cleaning the frame rail a bit before looking and then using a flashlight at an angle will sometimes make a lot easier to read accurately.
Old 12-28-2009, 06:16 PM
Toms53Ford's Avatar
Toms53Ford
The reason I wonder if it can handle the stroker is because every time I turn onto uneven ground (ie the truck is "tweaked" a bit) as in going up a curb with one tire up and one down it kind of "creeks". I'm not sure if it's a body mount or what but i've never had any issues.
  #28
Old 12-28-2009, 08:32 PM
55 f350's Avatar
55 f350
55 f350 is offline
earl how the hades did you get into the place i got my new frame stashed at and take a pic without my knowledge ???????????? LOL ..................................
  #29
Old 12-29-2009, 06:52 AM
Earl's Avatar
Earl
Earl is offline
We crafty ones never tell our secrets. It's sorta like being Santa, only he's skinnier.
  #30
Old 12-29-2009, 09:22 AM
AXracer's Avatar
AXracer
AXracer is offline
Tom, the stock frame is designed to twist. Not knowing what you actually have makes it hard to diagnose your "creak", but if the frame was swapped then it may be coming from however they mounted the cab and other components.
What type suspension does your truck have front and rear?
Quick Reply: New member here! Have a few questions!
