1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
More power out of a 5.4 Triton
Old 12-23-2009, 05:41 PM
dfboothe's Avatar
dfboothe
dfboothe is offline
i've got a f250 with a 5.4ltr, and 4.10's, what can i do to get more horsepower/torque out of it? thanks for any help
Dylan
Old 12-23-2009, 06:15 PM
bbender85's Avatar
bbender85
bbender85 is offline
what year???
EDIT: if it's the '99 listed in your profile, get some OEM Power Improved cams for it; i've done your typical intake/exhaust/tuner on my '99 and it was a little help, but not a huge improvement... cams are on my to-do list this winter before it's trailer haulin' season again.
Old 12-23-2009, 06:22 PM
dfboothe's Avatar
dfboothe
dfboothe is offline
yeah it's a 99,
cams from Ford? i didn't think about that
Old 12-23-2009, 06:27 PM
bbender85's Avatar
bbender85
you can find take-out stock cams on ebay from time to time for cheap. and being an OHC engine... it should be a fairly easy install.
Old 12-23-2009, 07:45 PM
spinella's Avatar
spinella
spinella is offline
Old 12-24-2009, 01:29 AM
redford's Avatar
redford
redford is offline
Received 1,565 Likes on 913 Posts
The answer to your question depends on how much money you are willing to spend on your truck.
Cam change, better exhaust, a better manifold and cold air box will help some.
Nitrous Oxide, a turbocharger or even a supercharger would give you a large power boost.
Want more? Maybe a 605HP 4V crate engine from SVO would do it for you?
Ford Racing Romeo 605 HP Performance Crate Engine 5.4L 4V w/TVS Supercharger [M-6007-TVS] - $17,229.95 : Powered By Ford - Your only high performance parts supplier for your Ford car or truck, When you want it done right and done well there is only o
But, realistically, a few minor engine mods and a gearing change in the differential are probably all you need.
Old 12-24-2009, 04:06 AM
TexasRebel's Avatar
TexasRebel
TexasRebel is offline
the easiest answer is:
put your foot down...
Old 12-24-2009, 05:54 AM
spinella's Avatar
spinella
spinella is offline
thats good, don't know how i overlooked that.
Old 12-24-2009, 07:13 PM
TexasRebel's Avatar
TexasRebel
yikes!
I just looked up a few cams for these engines...
I've rebuilt entire longblocks for less...
Old 12-24-2009, 09:14 PM
ken kenmnedy's Avatar
ken kenmnedy
ken kenmnedy is offline
I got a set of comepleat PI heads with cams and intake and hole motor [cracked block)
Old 12-24-2009, 09:28 PM
dfboothe's Avatar
dfboothe
dfboothe is offline
yeah tuner is first on my list, saving up for it now,
new engine is prolly on the extreme side,
i like the put your foot down option, i do that from time to time to remind myself is a FORD, and will haul a$$
Old 12-24-2009, 10:14 PM
1975StroppeBaja's Avatar
1975StroppeBaja
1975StroppeBaja is offline
A gear ratio change would probably give you the most bang for your buck. Go up to 4.30 or 4.56 and that'll help the feel of the truck.
Old 12-25-2009, 11:03 AM
ClintD1's Avatar
ClintD1
ClintD1 is offline
What year did the triton 5.4 come with PI heads?
I didn't know this even applied to the SD trucks. I'm only used to the 4.6 NPI / PI car engines.
got a nice 32valve 4.6 for a ranger project I'm doing, but that's another story.
Old 03-26-2010, 05:45 PM
2dub's Avatar
2dub
2dub is offline
Well ... just got the truck back today ...
Finally got the Gear change 3:73 --> 4:56. Some said "wow, thats steep" some said "you'll love it, another said "you're gona hate that thing on the highway" .... I definitely feel the difference, not sure what I was expecting...still a bit tough to spin these 35s on pavement
Satisfied, for now ... another 2k spent and got a little pep, but still searching for more pull...
Old 03-26-2010, 05:54 PM
Fordfanatic4life's Avatar
Fordfanatic4life
Fordfanatic4life is offline
shame you didnt go to 4:88's...
your comnig from the same gears i have and spinnin the same size tires i do.. i would go 4:88's for 35"s..
it puts you above the stock gearing numbers when you balance out the bigger tires..
going to 4:56 puts you back about where the truck was stock
still now that your done with the regear, you can do the tuner and i bet that will liven up your truck nicely.
p.s. repost with some mileage numbers after a few tanks if you dont mind comparing before and after teh regear.
Quick Reply: More power out of a 5.4 Triton
