ford 289 Engine help
Hi all got a 289 ford v8 engine in my truck which has'nt been started for 5 years. It all turns over nicely buy hand and was running good 5 years ago.
so changed the plugs and leads and got a new starter motor for it. But it wont turn over fast enough to start, but if i take the plugs out it turns over quick. so could any body help?? where am i going wrong?? Dont want to take the motor out and strip it. I also change the oil and filter.
But also, if it hasn't been run in five years, you need to "re-oil" all the moving parts.
Remove the spark plugs and squirt a little transmission fluid in each cylinder. Then, with the plugs out, crank it over for about 10 seconds, let it sit for a minute or two then crank it for ten seconds again. The two minutes is to prevent overheating of the starter motor.
This will draw oil up out of the pan and shoot it into the bearings and rings. It will also relubricate your seals - that's important because you don't want to start it up with those dry.
This will exercize all the moving parts while not under the stress of compression and also ensure your fuel pump has drawn fuel from the tank and has filled the carb (unless the needle valve is stuck).
If you have an oil pressure gauge repeat this until you start to see the oil pressure come up.
Then reinstall the plugs and try again. Should be fine.
yep the battery is fully charged. and i cleaned the points.
Timing advance was also my first guess. Another is internally corroded battery or starter cables. Cables can look good on the outside but be full of corrosion on the inside, especially if sitting a long time, not allowing the amperage needed to pass thru to the starter, causing slow spinning under load.
Remove the coil wire from the coil That go's to the center of the cap, remove the distributer cap and lay to one side. have somebody crank the engine a few turns as you observe the points to see if they open and close, you will see a spark each time they do. Or have one of your buddys hold on to the spark plug wire as you crank it and he will tell you if you are getting spark to the plugs. L.O.L. Second thought maybe don't do the last suggestion.
He said it was running 5 years ago. I wouldn't think most likely anyone moved the dist. He replaced the starter. Moisture could have been the cause for its failure, so I suspect the tank may have moisture. Even on a slow turnover with spark and fuel it should have tried to start, bucked, something. A set of jumper cables would have eliminated the battery and cables and maybe the slow start. Just trying to cover what hasn't been reviewed. merry xmas, chuck
