So its starting to get pretty cold here in Ontario, so i want to switch to a lighter oil. I have always used Mobil 1 so i figured i would pick up some Mobil 1 turbo diesel 5w-40.... but i cannot find mobil 1 turbo diesel anywhere? Where do you ontarians get your oil? Or what other type of oil should i be looking for?
Canadian tire carries rotella full synthetic 5w-40.Mobil delvac 5w-40 synthetic might have to be found at any large truck shop ie: Peterbilt,kenworth,freightliner it will be cheaper there also because it can be bought in 5 gallon pails.Good luck
If you can afford it.................do what I did...call a local distributor and get a 55 gal. drum. You'll spend extra money for a pump, but you will be saving $ every oil change you do and won't have to worry about locating it at the local stores.
