High Pressure power steering hose
I have changed this hose a few times, here is how I go about it
1 disconnect batteries.
2 remove drivers side battery
3 remove battery tray/ airfilter
4 remove driverside CAI pipe
5 replace hose
6 reinstall everything in opposite order.
It takes me about 30 min to do it this way.... An hour or more leaving everything in place
5 replace hose
Pop and jetdoc, no, no damage, plenty of fluid still in the res. I limped it home and washed underneath to find out if it wasn't just a back burp of fluid out the cap of the resovoir but its coming from one of the pressure hoses so I ordered all of them today via web order. I didn't hear any whining on the way back home so, we should be good, I hope, I'' let you all know. Just to let you know, I was taking advatage of my free lifetime tire rotations until the previous tire rotation the fella was jacking my truck up using the rear shock mounts and under the front u-bolts, I seen the shock mount later that evening was bent up and the front u-bolts were buggered up, I was ticked to no end and called to complain. Told this young fella don't do what the other guy did, under the axles I told him, and he did, then this. Done with them now.
Depending on your mileage I'd replace all of them, high and low pressure hoses and cooler hoses. Prevenitive maintence on the other hoses that didn't leak or blow on my truck makes me feel better. Remember, pay a little now or possibly pay big later. (breakdown)
#30
I guess it was my turn to join the club, lol! Can't complain since I have almost 300k miles and have never replaced it before.
It sounds like its a PITA but I shouldn't have to remove anything? It blew in the back part of my property where I have no tools or lights or anything. Just wondering so I can doit all at once... :-)
Also, once it's been replaced, do I need to flush the system or just fill and go?
